#1 2023-08-15 21:48:21
deepforest
Ceres upgading error to kernel 6.4
Hi again Folks!)
I have situation upgrading Ceres from kernel 6.1 to 6.4
Is there solution for that?
Why its happens?
I use standalone patched legacy 340 driver for my gf9800gtx
https://aur.archlinux.org/packages/nvidia-340xx
https://www.if-not-true-then-false.com/ … dia-guide/
root@home:/# dpkg -l *nvidia*
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                             Version      Architecture Description
un  libgldispatch0-nvidia            <none>       <none>       (no description available)
un  libnvidia-encode1                <none>       <none>       (no description available)
un  nvidia-alternative               <none>       <none>       (no description available)
un  nvidia-legacy-340xx-vdpau-driver <none>       <none>       (no description available)
un  nvidia-legacy-390xx-vdpau-driver <none>       <none>       (no description available)
un  nvidia-libopencl1-dev            <none>       <none>       (no description available)
un  nvidia-tesla-418-vdpau-driver    <none>       <none>       (no description available)
un  nvidia-tesla-440-vdpau-driver    <none>       <none>       (no description available)
un  nvidia-vdpau-driver              <none>       <none>       (no description available)
root@home:/# dkms status
nvidia/340.108, 6.1.0-9-amd64, x86_64: installed
root@home:/#
root@home:/home/freeartist-devuan# apt upgrade
Calculating upgrade... Done
  clearlooks-phenix-deepsea-theme g++-12 gcc-12-base:i386 glx-alternative-mesa libavdevice59 libavfilter8 libavformat59 libcaca-dev libcodec2-1.0 libjpeg-turbo-progs libmujs2 libnetpbm11
  libnvidia-legacy-340xx-eglcore libnvidia-legacy-340xx-eglcore:i386 libnvidia-legacy-340xx-glcore libnvidia-legacy-340xx-glcore:i386 libplacebo208 libpostproc56 libqt5sql5
  libqt5sql5-sqlite libslang2-dev libstdc++-12-dev libswscale6 libturbojpeg0 linux-image-5.10.0-21-amd64 linux-image-6.1.0-7-amd64 netpbm update-glx
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up linux-headers-6.4.0-2-amd64 (6.4.4-3) ...
/etc/kernel/header_postinst.d/dkms:
dkms: running auto installation service for kernel 6.4.0-2-amd64.
Sign command: /lib/modules/6.4.0-2-amd64/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Building module:
Cleaning build area...
make -j4 KERNELRELEASE=6.4.0-2-amd64 -j4 module KERNEL_UNAME=6.4.0-2-amd64; make -C uvm module KERNEL_UNAME=6.4.0-2-amd64 KBUILD_EXTMOD=/var/lib/dkms/nvidia/340.108/build/uvm...(bad exit st
atus: 2)
Error! Bad return status for module build on kernel: 6.4.0-2-amd64 (x86_64)
Consult /var/lib/dkms/nvidia/340.108/build/make.log for more information.
dkms autoinstall on 6.4.0-2-amd64/x86_64 failed for nvidia(10)
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
dkms: autoinstall for kernel: 6.4.0-2-amd64 failed!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11
Failed to process /etc/kernel/header_postinst.d at /var/lib/dpkg/info/linux-headers-6.4.0-2-amd64.postinst line 11.
dpkg: error processing package linux-headers-6.4.0-2-amd64 (--configure):
 installed linux-headers-6.4.0-2-amd64 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-headers-amd64:
 linux-headers-amd64 depends on linux-headers-6.4.0-2-amd64 (= 6.4.4-3); however:
  Package linux-headers-6.4.0-2-amd64 is not configured yet.
dpkg: error processing package linux-headers-amd64 (--configure):
Setting up linux-image-6.4.0-2-amd64 (6.4.4-3) ...
/etc/kernel/postinst.d/dkms:
Building module:
atus: 2)
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11
dpkg: error processing package linux-image-6.4.0-2-amd64 (--configure):
 installed linux-image-6.4.0-2-amd64 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-image-amd64:
 linux-image-amd64 depends on linux-image-6.4.0-2-amd64 (= 6.4.4-3); however:
  Package linux-image-6.4.0-2-amd64 is not configured yet.
dpkg: error processing package linux-image-amd64 (--configure):
 linux-headers-amd64
 linux-image-amd64
smile
pyzNi 3.14zDa! smile
#2 2023-08-15 22:04:26
Re: Ceres upgading error to kernel 6.4
No solution, but it is quite similar in daedalus using the liquorix kernel. It worked up to 6.3, 6.4 shows an error as above.
#3 2023-08-15 22:13:10
deepforest
kernel panic after reboot
https://ibb.co/wK4Nhwn
smile
#4 2023-08-16 00:10:43
deepforest
kernel panic resolved
installed driver 340.108 6.3+
now Xorg not starting
here Xorg logs
https://fex.net/s/kaa6r4s
smile
#5 2023-08-16 00:24:48
deepforest
use nouveau
desktop not load
console is working
cant upgrade now
https://ibb.co/sPYkHH2
smile
#6 2023-08-16 00:45:38
What else would you expect but instability when you play on the bleeding edge of "unstable" (sid)? What you are experiencing is the norm . . .
#7 2023-08-16 02:14:23
deepforest
its not unstable issue
what you can say about xorg logs?
smile
#8 2023-08-16 03:00:09
Not a thing. Have never had a display issue on Devuan.
#9 2023-08-16 05:56:24
To complete #2:
I never tried to boot the kernel with the error during module compilation, just returned to daedalus' 6.1.
And there is a nvidia card involved as well, using the current driver version.
#10 2023-08-16 16:40:26
deepforest
o really?:)
may be its because you not using gf9800gtx with standalone drivers!?:)
Are you really admin here? i am not sure because you do not answer to subject but spaming flood:)
If you cant give true help - pass throgh with silence.
smile
