#1 2017-05-07 19:01:08
chdsl
Update problem
I suppose the question has to be asked here. How to get out of this problem?
/var/cache/apt/archives/desktop-base_1%3a1.1_all.deb
#2 2017-05-07 19:49:57
Centurion Dan
Re: Update problem
I guess it depends largely on how you got there.
Are you running jessie, ascii or ceres?
can you find the lines in the backlog relating to installing desktop-base?
#3 2017-05-07 19:59:08
chdsl
Re: Update problem
Running Jessie. The problem happens when trying to upgrade Jessie.
#4 2017-05-07 20:00:32
Re: Update problem
Any non-jessie repos in the mix?  Even backports can be troublesome.
#5 2017-05-07 20:02:58
chdsl
Re: Update problem
All Jessie repos
# deb http://auto.mirror.devuan.org/merged/ jessie main
deb http://auto.mirror.devuan.org/merged/ jessie main non-free contrib
# deb-src http://auto.mirror.devuan.org/merged/ jessie main non-free contrib
# jessie-security, previously known as 'volatile'
deb http://auto.mirror.devuan.org/merged/ jessie-security main contrib non-free
# deb-src http://auto.mirror.devuan.org/merged/ jessie-security main contrib non-free
# jessie-updates, previously known as 'volatile'
deb http://auto.mirror.devuan.org/merged/ jessie-updates main contrib non-free
# deb-src http://auto.mirror.devuan.org/merged/ jessie-updates main contrib non-free
