#1 2023-08-14 21:28:14
davmes
[SOLVED] Deleted top window bar
I was cleaning up the top menu bar by getting rid of obsolete items. I selected an item and clicked delete and it deleted the entire menu bar. How do I get it back? Thanks.
#2 2023-08-14 22:07:40
Re: [SOLVED] Deleted top window bar
Right click on the "tab" bar and tick the box for the menu bar.
#3 2023-08-14 22:47:56
also, Alt+F3 may bring up the menu to set the bar, etc.
#4 2023-08-15 19:16:57
davmes
I tried both suggestions and the problem remained.
I rummaged on the web and discovered that the top menu bar reappeared by installing LXDE. Then booting with LXDE and restarting selecting MATE.
#5 2023-08-16 08:21:25
Was this on XFCE, the default desktop environment?
(If not, you should have said which environment you were using!) wink
