#1 2023-04-20 21:06:39
supusr
[SOLVED] Download Daedalus Xfce with non-free software
I have been using Debian Testing (bookworm) for a couple of months and it is great, especially since it now includes the non-free software necessary for wifi, etc.  The only problem is systemd.  I would like to use Devuan Daedalus Xfce if it would be essentially the same thing without systemd.  If that is the case, where is the download link?
Non-technical user, but Linux only since 2012.  Retired union business agent.  Avid reader.  Leftie.  English-Spanish.
#2 2023-04-20 21:09:36
Re: [SOLVED] Download Daedalus Xfce with non-free software
#3 2023-04-22 15:59:56
supusr
Nothing newer than 2021?  That version wouldn't reflect the new Debian policy of including non-free packages, would it?  This seems non-responsive to the original post.  Am I missing something?
#4 2023-04-22 16:23:23
You need to dig a bit deeper into the path on your selected server. The Daedalus directory it self was created in 2021, below you should find up to date previews, the latest seems to be dated March 27th.
BTW: basic non-free stuff is already integrated, there are no separate isos as with Debian.
#5 2023-04-22 17:03:36
Take a look here - https://ftp.nluug.nl/pub/os/Linux/distr … _chimaera/
or here - https://ftp.nluug.nl/pub/os/Linux/distr … _daedalus/
#6 2023-04-22 17:47:07
supusr
Thanks to you both.  I found the March 2023 one.  Btw, as of Debian 12 (testing at this time) there are no separate .isos for Debian, either.
