#1 2023-02-14 06:10:32
Danielsan
[SOLVED] Have been arm images dimissed?
Hello,
I am trying to an image for the RPI2 but I couldn't find in the arm page:
README.txt                                         14-Oct-2021 12:59    1837
SHA256SUMS                                         15-Feb-2022 02:26    1530
SHA256SUMS.asc                                     22-Oct-2022 14:03     488
devuan_chimaera_4.0.0_amd64_cd2.iso                12-Oct-2021 11:36    537M
devuan_chimaera_4.0.0_amd64_cd3.iso                12-Oct-2021 11:44    572M
devuan_chimaera_4.0.0_amd64_cd4.iso                12-Oct-2021 11:53    618M
devuan_chimaera_4.0.0_amd64_desktop.iso            12-Oct-2021 11:28      3G
devuan_chimaera_4.0.0_amd64_netinstall.iso         12-Oct-2021 10:48    372M
devuan_chimaera_4.0.0_amd64_server.iso             12-Oct-2021 10:58    642M
devuan_chimaera_4.0.0_i386_cd2.iso                 12-Oct-2021 11:55    543M
devuan_chimaera_4.0.0_i386_cd3.iso                 12-Oct-2021 12:03    573M
devuan_chimaera_4.0.0_i386_cd4.iso                 12-Oct-2021 12:12    630M
devuan_chimaera_4.0.0_i386_desktop.iso             12-Oct-2021 11:45      3G
devuan_chimaera_4.0.0_i386_netinstall.iso          12-Oct-2021 10:50    405M
devuan_chimaera_4.0.0_i386_server.iso              12-Oct-2021 11:02    691M
devuan_chimaera_4.1_0_amd64_pool1.iso              15-Feb-2022 02:21      5G
devuan_chimaera_4.1_0_i386_pool1.iso               15-Feb-2022 01:26      5G
Has been the support for ARM dismissed? 🤷♂️
Thanks!
#2 2023-02-14 09:59:55
Re: [SOLVED] Have been arm images dimissed?
There's this old one, you could install & upgrade, but there should be a link to chimaera one too, somewhere, I'll need to take another look online.
https://pkgmaster.devuan.org/devuan/dists/beowulf/main/installer-armhf/current/images/netboot/mini.iso
Found them! smile
https://arm-files.devuan.org/
#3 2023-02-14 17:45:56
Danielsan
Found them! smile
Thanks, I found that page too, but it was just a lucky coincidence, then I got back to arm page and the official images were missing... And now I am curious and I want to understand if the ARM images are still officially supported!
#4 2023-02-14 18:03:05
Arm images are provided by the Devuan Arm community. They are not and never have been "officially" supported by Devuan.
#5 2023-02-14 18:09:16
Danielsan
Understood... I got confused because the name of the page...
#6 2023-03-19 20:15:00
So they are just added to the repo as long as they maintain them?
Btw, has anyone here actually had experience installing linux on arm?
Wondered how that works.
#7 2023-03-20 09:11:49
I've used both RaspiOS & Devuan ARM on my Raspberry Pi computers, they work well - I've yet to run any BSD successfully on them, it seems to be a more complex installation process - I'll get around to it one day though, as some do use BSD on RPi. wink
