#1 2022-12-29 17:38:57
dcolburn
[SOLVED] nginx version
Is there a reason why the nginx version in the repository is 1.18 rather than 1.19?
Their video tutorial recommends 1.19.
Or should it not represent a significant difference?
Thanks
#2 2022-12-29 17:53:08
Re: [SOLVED] nginx version
The package versions for the stable release are frozen some time before the release. That's why it's called "stable". There are a few notable exceptions to this, such as firefox-esr & chromium, because of the security risks of an outdated version.
See https://www.debian.org/doc/manuals/debi … tml#s3.1.3 & https://wiki.debian.org/DontBreakDebian … f_Syndrome for further explanations as to why the latest version might not be the best option.
#3 2022-12-29 18:05:50
dcolburn
OK, got it.
Back to chasing conflicts between files cited in a nginx video "How to Get Started With NGINX" and the files to which they link on github.
Someone didn't proof it, it seems ... sigh.
Thanks
#4 2022-12-29 18:19:38
That version might be in the "backports" repository. If it is, install selectively. Do not install the entire backports. You might have a look at this page
