#1 2022-12-28 20:29:58
dcolburn
[SOLVED] nginx as web-server OK with Devuan
I have nginx installed plus nftables.
Is there any reason to not use nginx as the web-server with Devuan?
https://docs.nginx.com/nginx/admin-guid … eb-server/
Thanks
#2 2022-12-28 21:45:14
Re: [SOLVED] nginx as web-server OK with Devuan
AFAIK, Devuan's infrastructure runs on nginx. smile
#3 2022-12-28 22:49:20
dcolburn
Cool ... so they play nicely together. That's a bonus.  :-)
I'm now learning about setting up the web-server configuration here ...
https://docs.nginx.com/nginx/admin-guid … ion-files/
Thanks
