#1 2022-12-11 00:30:13
ljlinde
Setting up User accounts - needs improvement
We have a bout 50 systems in our shop.
Currently we are using Win 10, SL 6.5 and Sl 7.5. and one Devuan 4.0
Since RH has been IBM-d we plan to update all systems to Devuan.  The two test boxes have been running for about a year.  We can run all of our cad packages and everything works.
The only hard part is to setup users.   We maintain all users with a unique USID over all systems.   So if you need anything just set down to a box and login.
and you have acess to your account and the server.
SL 6.5 uses a dialog that allows you assign a user name, USID, and group.   Shamelessly copy it and add it Devuan
The test box is running an 8 core AMD with 32 G of ram and 4 T Byte disks with a SSD for the OS.  Incredible performance.
Cad Packages we run:
VariCad
Eagle
Spice
Several in house simulations with random access I/O of variables.
VMWare 17:
      NT 2000 so we can access our old autocad files in orrig. format.
      DOs
      Win 7
      Win 10
These are used to support projects from the last 24 years.
What we do is design and build custom embedded system.  Software and hardware.
I am one of those  condesending UNIX user accprding tp Dilbert.
I would also like to make a donation.  Send infol.
We were ready to can a Toshiba 32 bit laptop.  We installed a 1 TB ssd and Devuan and it really came to life.  Runs 32 bit versions of our cad packages with out a problem.  Save us a log of $$ on new laptops.  Just breaks my heart to see investments of 100 or $ put in trash pile.
Thank You
ljlinde
#2 2022-12-11 10:31:36
Re: Setting up User accounts - needs improvement
I'm not sure the developers have the time to pander to your whims d00d. They're pretty fucking busy already, from what I understand.
Do you have a link to this magical tool you describe? I can have a look and offer some porting suggestions if you want.
#3 2022-12-11 10:33:12
Have a look at gnome-system-tools. Included is an users and groups dialogue that offers all you want.
#4 2022-12-15 22:54:36
pungentweasel
I think the tool SL used in 6.5 might be "system-config-users". It was removed in RH 7.  (SL uses the same version numbering as RH)
It looks like the application has been abandoned now, but Fedora still has it:
https://than.fedorapeople.org/system-config-users/
You can also get source here:
https://gitlab.com/tallero/system-config-users
You could always try compiling it yourself and see if it works for you. It requires libuser which is available in the Devuan repos.
Also... here you go: https://www.devuan.org/os/donate
Behold, I send you forth as sheep in the midst of wolves: be ye therefore wise as serpents, and harmless as doves. - Matthew 10:16
#5 2023-01-04 08:28:41
lhp
I'm a very new Devuan user, but I guess I could claim being a VUA, having been root on 7 different Unix variants (not counting different Linux distributions) since the early 1990s. Isn't this just a matter of writing a tiny shell/awk/Perl script and/or perhaps setting up a little LDAP server and doing some /etc/nsswitch.conf configuration? Or maybe just good old NIS/YP? You could even distribute /etc/passwd (shadow, group) in a pinch?
#6 2023-01-04 15:55:05
@lhp . . . Welcome to devuan!  Please do share your wisdom . . . smile
