#1 2022-12-03 19:46:04
deepforest
I am tired from Ceres glitches
Isues:
-no network after booting
-no devices in thunar after booting
-nvidia driver installation issue
and many others...
PS i am On Ceres and runit
Can i without reinstalling move back to stable Devuan? But I'm not sure that this will solve all these problems...
smile
pyzNi 3.14zDa! smile
#2 2022-12-03 20:56:22
Re: I am tired from Ceres glitches
Why are you beating yourself in the head with hammer by using an unstable release? If you want things to "just work", use the current stable release, Chimaera.
#3 2022-12-03 21:10:35
deepforest
Can i migrate now from unstabe to stable without reinstalling?
approve that is all ONLY unstable issues?!
smile
#4 2022-12-03 21:15:39
changing the release is always the same.
edit /etc/apt/sources.list - replace ceres with chimaera
apt update
apt upgrade
apt dist-upgrade
To downgrade or make apt install older packages over newer:
cat /etc/apt/preferences
Package: *
Pin: release n=chimaera
Pin-Priority: 1001
I messed the file up here https://dev1galaxy.org/viewtopic.php?id=5208
apt -s whatever does a dry run.
#5 2022-12-03 21:28:11
deepforest
Thanks!
I hear that i can do only UPgrade distro, but DOWNgrade can cause many issues
smile
#6 2022-12-03 21:44:09
Why not just start from scratch with a fresh install?
#7 2022-12-03 21:55:57
Devarch
deepforest wrote:
Thanks!
Yes
Sometimes some config files etc are not the same. You can finish with broken system.
#8 2022-12-03 22:20:46
Worst case is a new installation ... . Anyway.
Probably you want to migrate to daedalus?
It is closer to ceres.
#9 2022-12-03 23:36:57
sgage
FWIW, I have zero issues with daedalus - been using it for some time. (I use MATE)
#10 2022-12-03 23:44:30
deepforest
Because root and home partitions on same disk. Home folder use almost 90% of this disk and i have very many installed and compiled software that i do not want to loose or starting installing or compiling from scratch.
smile
#11 2022-12-03 23:51:03
deepforest
why mean daedalus/ceres for me?
i have only one repo
deb http://deb.devuan.org/merged ceres main contrib non-free
freeartist@devuan:~$ neofetch
   ..,,;;;::;,..                   freeartist@devuan
           `':ddd;:,.              -----------------
                 `'dPPd:,.         OS: Devuan GNU/Linux 5 (daedalus/ceres) x86_64
                     `:b$$b`.      Host: P31-DS3L
                        'P$$$d`    Kernel: 6.0.0-5-amd64
                         .$$$$$`   Uptime: 4 hours, 36 mins
                         ;$$$$$P   Packages: 3248 (dpkg), 16 (flatpak)
                      .:P$$$$$$`   Shell: bash 5.2.2
                  .,:b$$$$$$$;'    Resolution: 1920x1080
             .,:dP$$$$$$$$b:'      DE: Xfce 4.16
      .,:;db$$$$$$$$$$Pd'`         WM: Xfwm4
 ,db$$$$$$$$$$$$$$b:'`             WM Theme: Arc
:$$$$$$$$$$$$b:'`                  Theme: Adwaita [GTK2/3]
 `$$$$$bd:''`                      Icons: Adwaita [GTK2/3]
   `'''`                           Terminal: mc
                                   CPU: Intel Core 2 Quad Q6600 (4) @ 2.400GHz
                                   GPU: NVIDIA GeForce 9800 GTX+
                                   Memory: 2149MiB / 3927MiB
smile
#12 2022-12-04 10:34:54
I'm happily running daedalus, repo is
deb http://deb.devuan.org/merged daedalus main contrib non-free
The output of neofetch regarding OS, Kernel and Shell is equal.
Not exactly sure about the OS name "daedalus/ceres".
Packages are tested in ceres, before integrated in daedalus.
(edit: typo)
#13 2022-12-04 10:57:21
That is taken from /etc/os-release, which is provided by the base-files package. That line always lists either stable or testing/unstable (by names), it never distinguishes between the development branches.
EDIT: one of the reasons for this is that most experienced users of the development branches will have both testing and unstable in their sources (and perhaps even stable as well), with the appropriate pinning.
#14 2022-12-04 20:08:53
xinomilo
Unknown
still on ceres and runit. still can boot, still got network, still got all devices.. (no nvidia sh*t).
#15 2022-12-04 20:11:14
deepforest
and what gives runit compare to sysv?
smile
#16 2022-12-04 20:14:27
xinomilo
Unknown
offtopic.
#17 2022-12-04 21:55:58
deepforest
no, explain please, feel free its my topic smile
smile
#18 2022-12-05 16:21:01
deepforest wrote:
its my topic
Not really. These boards are a community resource so please treat them as such. Thanks.
Ideally each thread should have a clear title describing a single problem. This helps other users who may encounter that same problem and makes it easy to find with the forum's Search feature.
Threads like this with a vague, meaningless title and no clear aim are more or less useless to everybody. Only experienced users should run the development branches, everyone else should run the stable release. "Glitches" are to be expected when running unstable because the whole point is to fix them before they make it to stable.
#19 2022-12-05 20:12:45
deepforest wrote:
Because root and home partitions on same disk... .
It's called "stepping on your own tail" smile
The two "/" partitions, the /home and swap partitions allow for many more options.
On one, a stable release for all cases, on the other, roling for experiments.
This is from my own experience.
#20 2022-12-05 20:43:04
I like to use btrfs so I can have an unlimited number of root & /home subvolumes in the same partition. And the snapshots really help with a development branch — set up automatic snapshots before every update and just rollback if there are any problems.
