#1 2022-11-26 16:51:33
dp
Elementary my dear Watson...
Where does one go to learn how to post things such as a log into a scroll-able window into the forum. Thank you.
#2 2022-11-26 17:32:05
Re: Elementary my dear Watson...
Hi dp!
On the "Post a reply" page there is a line of BB code functions about an inch above the input box.
First one "u" is to underline.
Towards the end look for "code"
to enclose scrollable code
Hilight the text you want to tag and then click on the desired function and viola!
#3 2022-11-26 19:12:58
The easy links Go pointed to sure are nice, but it's all just fairly standard BBCode under the hood. For all the other things you can do with it, the 'net abounds with generic BBCode explanations, or click the "BBCode" link at the bottom of the editor frame.
#4 2022-11-27 00:03:36
dp
Excellent.  That helps to get off the ground.
