#1 2022-11-01 06:45:49
amc252
Select only needed firmware
The Debian/Devuan installer has a rather neat feature (which I haven't seen in any other installer AFAIK), that is to detect and install only the firmware needed by the computer in use.
I was wondering if this feature can be replicated by some commands on the terminal, I mean at least determining precisely what firmware drivers the system needs.
Thanks.
#2 2022-11-01 06:59:44
Re: Select only needed firmware
# apt install isenkram
# isenkram-autoinstall-firmware
EDIT: or perhaps
# isenkram-pkginstall
I've never actually used it though.
#3 2022-11-01 07:03:57
amc252
EDIT: or perhaps
I have seen the suggestion about isenkram on the Debian wiki. Is that what the installer use?
It's a 10mb download and I was wondering if there was a commandline alternative.
#4 2022-11-01 12:11:13
Kelsoo
isenkram-cli
#5 2022-11-01 13:38:46
Another alternative is to check dmesg and see what the kernel says is missing then find those files and place them under /lib/firmware/.
I don't know. I haven't used the chimaera installer.
#6 2022-11-01 13:53:24
Evenson
I believe it is a setting in /etc/initramfs.conf
# initramfs.conf
# Configuration file for mkinitramfs(8). See initramfs.conf(5).
# Note that configuration options from this file can be overridden
# by config files in the /etc/initramfs-tools/conf.d directory.
# MODULES: [ most | netboot | dep | list ]
# most - Add most filesystem and all harddrive drivers.
# dep - Try and guess which modules to load.
# netboot - Add the base modules, network modules, but skip block devices.
# list - Only include modules from the 'additional modules' list
MODULES=most
"A stop job is running..." - SystemD
#7 2022-11-01 14:19:00
That's just for the initramfs. Setting MODULES=dep wouldn't cause any firmware packages to be installed or removed.
#8 2022-11-01 14:27:30
Evenson
No that just determines the device drivers to load, not the packages to have available which is what i thought OP was querying?
#9 2022-11-01 14:33:31
Hmm, I thought the opposite hmm
We'll have to wait for the OP to clarify.
#10 2022-11-01 14:40:11
Evenson
Bit of both i think. I was of the opinion that the installer made all free and non-free firmware like network firmware available at install and you had to choose non-free sources to have those packages available after the install. Particularly when using expert installation, im not sure about guided installs?
#11 2022-11-01 15:01:08
Official Devuan policy from https://www.devuan.org/os/install:
Non-free firmware packages are available on all install media. These packages will only be installed if required by your wifi adapter. To avoid the automatic installation and loading of needed non-free firmware, choose the Expert install option during the installation process.
The desktop-live and minimal-live images have non-free firmware packages pre-installed. These packages may be removed after boot using the remove_firmware.sh script available under /root.
#12 2022-11-01 15:55:22
amc252
Thank everybody for your suggestions.
I think my question was twofold:
1) I was curious as to how the installer checks which firmware drivers (whether free or non-free - by the way Debian installer asks permission if non-free drivers are needed whereas Devuan just installs them, both on expert and guided mode) and then proceeds to install them.
2) I wanted to know if there was a way to do the same after the install doing some commandline magic, maybe using grep or something.
I tried isenkram on a test install, and efectively it detects and installs some missing firmware. It just requires to install isenkram + deps, which on my system was about 10mb.
Somehow, my question is a bit academic, since Devuan does what I need and Devuan is what I use, but I might want to do the same if I install some other distro for testing.
#13 2022-11-02 12:36:49
Ogis1975
amc252 wrote:
Hello. This not a new feature. This feature has been around for a long time.
            ----+- Peter Kropotkin -+----
#14 2022-11-02 17:01:55
amc252
Ogis1975 wrote:
amc252 wrote:
Yes, when I said I haven't found it in any other installer I was referring to other distros. One of many reasons why I love Debian and love Devuan even more.
