#1 2022-10-06 18:13:09
tux
No Sound ALSA
No sound since installation.
packages Pulse Audio, Pavacontrol deleted, intend to keep it ALSA only along with Qasmixer, alsamixergui and amixer-gtk
pulseaudio, pavacontrol and firmware-non-free at installation had no sound.
drivers not support, driver is on ALSA list of unsupported drivers.
the notorious intel Cirrus Logic Generic
full .config
[code]/etc/asound.conf
defaults.pcm.card 1
defaults.pcm.device 0
defaults.ctl.card 1[/code]
cat /proc/asound/cards
 1 [PCH            ]: HDA-Intel - HDA Intel PCH
                           HDA Intel PCH at 0x92720000 irq 59
lspci -nn |grep -i audio
00:1f.3 Audio device [0403]: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller [8086:a170] (rev 31)
01:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X] [1002:aae0]
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 1: PCH [HDA Intel PCH], device 0: Generic Analog [Generic Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
/etc/modprobe.d/options
options snd-hda-intel model=imac18,2
!!Amixer output
!!-------Mixer controls for card PCH
Card hw:1 'PCH'/'HDA Intel PCH at 0x92720000 irq 57'
  Mixer name	: 'Cirrus Logic Generic'
  Components	: 'HDA:10138409,106b0f00,00100100'
  Controls      : 16
  Simple ctrls  : 2
Simple mixer control 'PCM',0
  Capabilities: pvolume
  Playback channels: Front Left - Front Right
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Digital',0
  Capabilities: cvolume
  Capture channels: Front Left - Front Right
  Limits: Capture 0 - 120
  Front Left: Capture 0 [0%] [-30.00dB]
  Front Right: Capture 0 [0%] [-30.00dB]
sudo amixer-gtk gives error, no sound when gui open.
ALSA lib pcm_hw.c:1829:(_snd_pcm_hw_open) Invalid value for card
  Mono:
  Front Left: Capture 62 [52%] [1.00dB]
  Front Right: Capture 62 [52%] [1.00dB]
no sound from changing volume of qasmixer, alsamixergui and alsa cli
#2 2022-10-06 19:03:26
Re: No Sound ALSA
Please use "code" tags. Legend is available above the edit window.  smile
#3 2022-10-06 22:07:51
hunter0one
Re: No Sound ALSA
Is Pulseaudio showing "Dummy Output"? I'm having the same issue on a Core 2 Duo machine I have set up with Devuan.
EDIT: Re-read it, forget about the above
#4 2022-10-06 23:03:23
Re: No Sound ALSA
@tux . . . Thanks for the edit. Do you have apulse installed? Needed when pulseaudio is removed. Not sure of the details.
#5 2022-10-07 15:45:23
Re: No Sound ALSA
Please provide a link to support this statement.
My research indicates both cards should have drivers:
https://linux-hardware.org/index.php?id … -1043-1d8d
https://linux-hardware.org/?id=pci:1002-aae0-1002-aae0
And you do have an analogue output device listed in the aplay output so clearly something has a driver.
Please post the full output of
speaker-test # in the alsa-utils package
Has the sound ever worked on this machine? Are you sure it's not broken?
EDIT: try the firmware-misc-nonfree, firmware-sof-signed and firmware-intel-sound packages.
EDIT2: or use the isenkram package to determine any needed firmware.
#6 2022-10-07 18:47:32
tux
Re: No Sound ALSA
apulse installed
no sound after running
OS the desktop comes with had sound
is bluetooth required?
output is
E: Unable to locate package firmware-intel-sound
debian packages only?
List of ALSA drive unsupported is on alsa wiki
also here
https://alsa.opensrc.org/Sound_cards
Playback device is default
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 2048 to 16384
Period size range from 1024 to 1024
Using max buffer size 16384
Periods = 4
was set period_size = 1024
was set buffer_size = 16384
 0 - Front Left
Time per period = 2.651964
 0 - Front Left
Time per period = 2.986003
 0 - Front Left
Time per period = 2.987338
 0 - Front Left
Time per period = 2.986686
#7 2022-10-07 19:19:45
Re: No Sound ALSA
My old Intel Haswell needed an .asoundrc file to sort the 2 chips on the board.  Maybe that's an option? Or more likely this is just noise and apologies for that . . .
#8 2022-10-07 19:39:05
tux
Re: No Sound ALSA
asoundrc not something i have tried
modprobe.d incorrectly set?
is devuan going to support firmware-sof-signed and firmware-intel-sound?
#9 2022-10-08 06:57:37
Re: No Sound ALSA
I didn't ask if that command produced sound.
I asked for the full output from that command. I need to see the full error message, if there is one.
output is
Nope:
https://pkginfo.devuan.org/cgi-bin/poli … d&x=submit
Fix /etc/apt/sources.list and update then try those packages again. If your sources are incomplete then *many* other packages might be missing.
#10 2022-10-08 08:27:55
tux
Re: No Sound ALSA
sudo '/usr/sbin/isenkram-autoinstall-firmware'
at end of output, not includeing amddrivers it found.
info: unable to find any local firmware info for dist chimaera, using info for sid
info: locating packages with the requested firmware files
info: determining whether enabling other components is required
info: No new firmware package with requested firmware detected.
sudo alsamixer set to
Card: HDA INTEL PCH
CHip: Cirrus Logic Generic
with only 1 volume PCH bar set to max%
sudo aplay /usr/share/sounds/alsa/*.wav output
Playing WAVE '/usr/share/sounds/alsa/Front_Center.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Playing WAVE '/usr/share/sounds/alsa/Front_Left.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Playing WAVE '/usr/share/sounds/alsa/Front_Right.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Playing WAVE '/usr/share/sounds/alsa/Noise.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Playing WAVE '/usr/share/sounds/alsa/Rear_Center.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Playing WAVE '/usr/share/sounds/alsa/Rear_Left.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Playing WAVE '/usr/share/sounds/alsa/Rear_Right.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Playing WAVE '/usr/share/sounds/alsa/Side_Left.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Playing WAVE '/usr/share/sounds/alsa/Side_Right.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
speaker-test # in the alsa-utils package command nevers stops giving output
installed both firmware-sof and firmware-intel
still no sound
#11 2022-10-08 08:29:57
Re: No Sound ALSA
Please provide that output. This is the last time I will ask.
#12 2022-10-08 08:38:57
tux
Re: No Sound ALSA
how to copy full output while still running? keeps deselecting and jumping back to latest
0 - Front Left
Time per period = 2.986367
0 - Front Left
Time per period = 2.994606
0 - Front Left
Time per period = 2.978713
0 - Front Left
Time per period = 2.973439
0 - Front Left
Time per period = 2.999882
0 - Front Left
Time per period = 2.986659
0 - Front Left
Time per period = 2.986763
0 - Front Left
Time per period = 2.974354
0 - Front Left
Time per period = 2.998743
0 - Front Left
Time per period = 2.973441
0 - Front Left
Time per period = 2.999887
0 - Front Left
Time per period = 2.986530
0 - Front Left
Time per period = 2.986885
0 - Front Left
Time per period = 2.986628
0 - Front Left
Time per period = 2.979631
0 - Front Left
Time per period = 2.993528
0 - Front Left
Time per period = 2.986423
0 - Front Left
Time per period = 2.986678
0 - Front Left
Time per period = 2.986663
0 - Front Left
Time per period = 2.986716
0 - Front Left
Time per period = 2.995805
0 - Front Left
Time per period = 2.977301
0 - Front Left
Time per period = 2.986938
0 - Front Left
Time per period = 2.986406
0 - Front Left
Time per period = 2.973497
0 - Front Left
Time per period = 2.999753
0 - Front Left
Time per period = 2.986713
0 - Front Left
Time per period = 2.986560
0 - Front Left
Time per period = 2.986683
0 - Front Left
Time per period = 2.986770
0 - Front Left
Time per period = 2.986408
0 - Front Left
Time per period = 2.986693
0 - Front Left
Time per period = 2.986644
0 - Front Left
#13 2022-10-08 09:02:03
Re: No Sound ALSA
Thank you. That output indicates that the software side of things is working. A driver is assigned and the output is correct.
So are you sure the speakers actually work? When was the last time they produced sound? Do they work with any other live ISO?
#14 2022-10-08 12:07:43
tux
Re: No Sound ALSA
Desktop default OS sound always worked and sound for virtualbox antix and other os hopping tryouts.
After installing Devuan no sound.
Backported ALSA to get latest. Might Daedalus upgrade fix? blacklist driver?
#15 2022-10-08 14:19:55
Re: No Sound ALSA
I had a problem with sound, I switched over from a VGA monitor to a HDMI without built in speakers, but when I went back to the VGA monitor, everything was working fine - I don't think pulseaudio takes that fact into consideration, because I had it set to analogue stereo, which should have worked via the audio out socket.
#16 2022-10-08 15:49:26
tux
Re: No Sound ALSA
aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pulse
    PulseAudio Sound Server
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
hw:CARD=PCH,DEV=0
    HDA Intel PCH, Generic Analog
    Direct hardware device without any conversions
plughw:CARD=PCH,DEV=0
    Hardware device with all software conversions
default:CARD=PCH
    Default Audio Device
sysdefault:CARD=PCH
front:CARD=PCH,DEV=0
    Front output / input
surround21:CARD=PCH,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
dmix:CARD=PCH,DEV=0
    Direct sample mixing device
usbstream:CARD=PCH
    HDA Intel PCH
    USB Stream Output
lsmod | grep snd
snd_hda_codec_generic    98304  1
ledtrig_audio          16384  1 snd_hda_codec_generic
snd_hda_intel          57344  2
snd_intel_dspcfg       28672  1 snd_hda_intel
soundwire_intel        45056  1 snd_intel_dspcfg
snd_soc_core          319488  1 soundwire_intel
snd_compress           32768  1 snd_soc_core
snd_hda_codec         176128  2 snd_hda_codec_generic,snd_hda_intel
snd_hda_core          110592  3 snd_hda_codec_generic,snd_hda_intel,snd_hda_codec
snd_hwdep              16384  1 snd_hda_codec
snd_pcm_oss            65536  0
snd_mixer_oss          28672  1 snd_pcm_oss
snd_pcm               143360  7 snd_hda_intel,snd_hda_codec,soundwire_intel,snd_compress,snd_pcm_oss,snd_soc_core,snd_hda_core
snd_timer              49152  1 snd_pcm
snd                   110592  14 snd_hda_codec_generic,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,snd_compress,snd_pcm_oss,snd_soc_core,snd_pcm,snd_mixer_oss
soundcore              16384  1 snd
below are config suggestions foun don web, from people dealing with no sound output and ALSA only software.
cat /etc/modprobe.d/alsa.conf
options snd_hda_intel index=1,0
options snd-intel-dspcfg dsp_driver=1
nano /etc/modprobe.d/alsa-base.conf
options snd_hda_intel enable=1 index=0
options snd-hda-intel index=1,0
options snd-hda-intel dmic_detect=0
options snd-hda-intel model=pch position_fix=1
options snd-hda-intel model=mbp3
options snd-hda-intel model=imac18_2
options snd-hda-intel model=auto
inxi -F
Audio:
  Device-1: Intel 100 Series/C230 Series Family HD Audio
  driver: snd_hda_intel
  Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
  driver: N/A
  Sound Server: ALSA
below is snd blacklist to prevent conflict with othe snd settings.
/etc/modprobe.d/blacklist.conf
blacklist snd_soc_skl
This config file was empty.
/etc/modprobe.d/options *
jack setting are unmodified but might be conflicting with othe settings.
/etc/modprobe.d/hda-jack-retask.conf
options snd-hda-intel patch=hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retak-retask.fw,hda-jack-retask.fw
#17 2022-10-08 23:04:11
Re: No Sound ALSA
I can redirect > the output to a file and then use the file.
CTRL+C ENTER will stop the pink noise when the buffer is empty (takes a couple of secs).
glenn@GamesBox ~ $ speaker-test > /home/glenn/Downloads/soundtest.txt
^C
glenn@GamesBox ~ $
## I had to hit enter after ctrl+c
speaker-test 1.2.7
Buffer size range from 192 to 2097152
Period size range from 64 to 699051
Using max buffer size 2097152
Periods = 4
was set period_size = 524288
was set buffer_size = 2097152
 0 - Front Left
Time per period = 10.952028
hth
Card: HDA INTEL PCH
still no sound
#18 2022-10-08 23:17:23
Re: No Sound ALSA
@tux perhaps you could describe briefly what the various snd-hda-intel options do for you?
#19 2022-10-09 08:48:15
tux
Re: No Sound ALSA
Ralph I edit ealier post and added reasons.
removed alsaplayer-oss know in rare cases of no sound
below is asound.state
state.PCH {
	control.1 {
		iface CARD
		name 'Internal Mic Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.2 {
		iface CARD
		name 'Mic Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.3 {
		iface CARD
		name 'Speaker Front Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.4 {
		iface CARD
		name 'Speaker Surround Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.5 {
		iface CARD
		name 'Headphone Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.6 {
		iface PCM
		name 'Playback Channel Map'
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		comment {
			access read
			type INTEGER
			count 4
			range '0 - 36'
	control.7 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.8 {
		iface PCM
		device 2
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.9 {
		iface PCM
		device 2
		index 1
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.10 {
		iface PCM
		device 2
		index 2
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.11 {
		iface PCM
		device 2
		index 3
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.12 {
		iface PCM
		device 2
		index 4
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.13 {
		iface PCM
		device 2
		index 5
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.14 {
		iface PCM
		device 2
		index 6
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.15 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.16 {
		iface MIXER
		name 'Digital Capture Volume'
		value.0 60
		value.1 60
		comment {
			type INTEGER
			count 2
			range '0 - 120'
			tlv '0000000100000008fffff44800000032'
			dbmin -3000
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
speaker-test -Dplug:surround51 -c6 -twav
Playback device is plug:surround51
Stream parameters are 48000Hz, S16_LE, 6 channels
WAV file(s)
Buffer size range from 32 to 262144
Period size range from 16 to 131072
Using max buffer size 262144
Periods = 4
was set period_size = 65536
was set buffer_size = 262144
 0 - Front Left
 1 - Front Right
 3 - Rear Right
 2 - Rear Left
 4 - Unused
 5 - Unused
Time per period = 13.707691
 0 - Front Left
 1 - Front Right
 3 - Rear Right
 2 - Rear Left
 4 - Unused
 5 - Unused
Time per period = 13.715830
#20 2022-10-09 10:59:04
tux
Re: No Sound ALSA
amixer
  Mono:
amixer contents
numid=1,iface=CARD,name='Internal Mic Phantom Jack'
  ; type=BOOLEAN,access=r-------,values=1
  : values=on
numid=3,iface=CARD,name='Line Out Phantom Jack'
  : values=on
numid=2,iface=CARD,name='Mic Phantom Jack'
  : values=on
numid=4,iface=CARD,name='Speaker Front Phantom Jack'
  : values=on
numid=5,iface=CARD,name='Speaker Surround Phantom Jack'
  : values=on
numid=15,iface=MIXER,name='PCM Playback Volume'
  ; type=INTEGER,access=rw---RW-,values=2,min=0,max=255,step=0
  : values=255,255
  | dBscale-min=-51.00dB,step=0.20dB,mute=0
numid=16,iface=MIXER,name='Digital Capture Volume'
  ; type=INTEGER,access=rw---RW-,values=2,min=0,max=120,step=0
  : values=0,0
  | dBscale-min=-30.00dB,step=0.50dB,mute=0
numid=7,iface=PCM,name='Capture Channel Map'
  ; type=INTEGER,access=r----R--,values=2,min=0,max=36,step=0
  : values=0,0
  | container
    | chmap-fixed=FL,FR
numid=6,iface=PCM,name='Playback Channel Map'
  ; type=INTEGER,access=r----R--,values=4,min=0,max=36,step=0
  : values=0,0,0,0
  | container
    | chmap-fixed=FL,FR
    | chmap-fixed=FL,FR,RL,RR
numid=8,iface=PCM,name='Capture Channel Map',device=2
  : values=0,0
  | container
    | chmap-fixed=FL,FR
numid=9,iface=PCM,name='Capture Channel Map',index=1,device=2
  : values=0,0
  | container
    | chmap-fixed=FL,FR
numid=10,iface=PCM,name='Capture Channel Map',index=2,device=2
  : values=0,0
  | container
    | chmap-fixed=FL,FR
numid=11,iface=PCM,name='Capture Channel Map',index=3,device=2
  : values=0,0
  | container
    | chmap-fixed=FL,FR
numid=12,iface=PCM,name='Capture Channel Map',index=4,device=2
  : values=0,0
  | container
    | chmap-fixed=FL,FR
numid=13,iface=PCM,name='Capture Channel Map',index=5,device=2
  : values=0,0
  | container
    | chmap-fixed=FL,FR
numid=14,iface=PCM,name='Capture Channel Map',index=6,device=2
  : values=0,0
  | container
    | chmap-fixed=FL,FR
amixer scontents
  Mono:
amixer sget Master
amixer: Unable to find simple control 'Master',0
what is debian command for pacmd link-sinks?
#21 2022-10-09 11:45:02
tux
Re: No Sound ALSA
mute button grey out in top left PNMixer, how unmute?
hotkey set to unmute not working
devuan comes without xfce4-mixer?
#22 2022-10-10 02:06:22
Re: No Sound ALSA
I resorted to .asoundrc to stop hdmi being loaded (on my desktop PC). Reliable...
#23 2022-10-10 16:50:21
tux
Re: No Sound ALSA
Glenn do have a config exsample to blacklist hdmi?
#24 2022-10-10 23:24:14
Re: No Sound ALSA
Yes I do. I'll put it here but be warned there are many modules that rely/depend on hdmi.
I stopped using the blacklist when I was trying to get BT sound reliably configured.
here is a copy...
/home/glenn/My_system/backup-sys-default/etc/blacklist.conf
# blacklisted modules for PCI coldplug
# see also /etc/modprobe.d/blacklist-compat
blacklist edac_mce_amd
blacklist edac
## Best not to blacklist modules that depend on eachother
blacklist snd_hda_codec_hdmi  #hdmi nvidia digital stereo
#blacklist snd_hda_codec_realtek #hda onboard 5.1 surround
#blacklist snd_hda_intel
#blacklist snd_usb_audio
blacklist rivatv
blacklist bluetooth
# For some bridges both intel-agp and i82875p_edac are loaded. If i82875p_edac
# is loaded first it will grab the device. Then intel-agp doesn't work.
# Therefore we disable automatic loading of 82875p_edac. (Bug 213840)
# https://bugzilla.novell.com/show_bug.cgi?id=213840
blacklist i82875p_edac
# do not use "Boot Protocol" drivers, we prefer usbhid
# and they cause problems when loaded together with usbhid (#37726, #40861)
blacklist usbkbd
blacklist usbmouse
# disable PC speaker by default
# pcspkr is the standard driver, while snd-pcsp is the ALSA driver
blacklist pcspkr
blacklist snd-pcsp
blacklist nouveau
blacklist nv
# Prevent conflicts with nvidiabl
blacklist nvidia_bl
blacklist nvbacklight
blacklist mbp_nvidia_bl
# End of entries added for nvidiabl
...in it's totallity... I think that file maybe a leftover from another distro.
I did this instead so the snd-hda* dependants satisfied
/home/glenn/My_system/backup-sys-default/etc/modprobe.d/snd-options
options snd-usb-audio index=0 bdl_pos_adj=16,16
options snd-cmipci mpu_port=0x330 fm_port=0x388
options snd_hda_codec_hdmi index=-2
options snd-pcsp index=-2
current /home/glenn/.asoundrc
#defaults.pcm.!card 0 #hdmi
#defaults.ctl.!card 0 #hdmi
# card 1 #usb-audio
#defaults.pcm.card 1 #usb-audio
#defaults.ctl.card 1 #usb-audio
# Generic_1
defaults.pcm.Generic_1 #usb-audio
defaults.ctl.Generic_1 #usb-audio
I don't have it blacklisted anymore.
current /etc/modules
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
snd-usb-audio
asus-wmi-sensors
#rtk_btusb
snd-pcm-oss
snd-mixer-oss
#snd-seq-oss
snd_seq
Hope this helps.
#25 2022-10-13 20:52:11
tux
Re: No Sound ALSA
glenn blacklist no sound after reboot.
