#1 2022-09-24 21:08:37
amc252
[SOLVED] netselect-apt output
I have installed netselect-apt but when I run it the output is:
        http://debian.osuosl.org/debian/
	http://mirror.dal.nexril.net/debian/
	http://mirror.it.ubc.ca/debian/
	http://mirror.estone.ca/debian/
	http://ftp.us.debian.org/debian/
	http://mirror.steadfast.net/debian/
that is, debian mirrors.
If I use the option |release_codename| chimaera I get:
$ sudo netselect-apt release_codename| chimaera
bash: chimaera: command not found
Invalid distribution: release_codename
So, how do I get to find out the fastest devuan mirrror?
#2 2022-09-24 21:23:27
Re: [SOLVED] netselect-apt output
Just use the round-robin redirector, as suggested on the Devuan site.
https://www.devuan.org/os/packages
#3 2022-09-24 21:35:03
amc252
in the page you indicated there is no mention of a round-robin redirector.
Also, is the netselect-apt package usable in Devuan?
#4 2022-09-24 22:04:14
Yes there is. Read it again. The page doesn't use that term but it only provides a single repository URL. Use it.
Doesn't look like it but that package has been irrelevant in Debian for several years now. CDNs ftw!
#5 2022-09-24 22:46:00
amc252
Thanks for the clarification.
Odd to keep in the repo a package that points to debian mirror though.
Just for curiosity, I ping-ed some of the mirrors in http://pkgmaster.devuan.org/mirror_list.txt
the closest to my location and the faster would be ocf.berkeley.edu (time=19.9 ms)
Too bad it gives an error "Release is expired (invalid since 314d 18h 52min 26s)"
the next best option, was dev.beard.ly ( time=41.6 ms)
whereas pkgmaster.devuan.org was ( time=183 ms)
#6 2022-09-24 22:57:20
Don't use pkgmaster.devuan.org, that's the main mirror.
The URL given on the page to which I linked should be optimal for everybody all around the world. That's why it's the only URL listed.
#7 2022-09-24 23:00:24
amc252
Thanks.
#8 2022-09-24 23:24:17
@amc252 . . . FYI this is how Devuan package mirrors are built.
