#1 2017-03-18 22:31:35
Cheerful Charlie
AMD Radeon driver
I have a Radeon 6670 GPU.  I want to install the AM catalyst drivers.  The online how-tos are for Debian.  What changes in that should i make if needed to accommodate Devuan in this regard?  The reason I want to do this is because I had a lot of trouble with the open source version under Mageia 5.0 and all that went away when I installed the proprietary drivers.
Cheerful Charlie
#2 2017-03-19 15:28:36
Re: AMD Radeon driver
Installing AMD proprietary drivers on devuan should be the same as on debian. I know it is the same for nvidia drivers, but I have no experience with the amd. Please report back whether it works or not. I'm sure you're not the only one with this question.
#3 2017-03-19 16:07:08
You could also give sgfxi a try.  It worked well for my Nvidia driver a few years back using the default settings.  Don't know whether it would find those specific drivers though . . .
#4 2017-04-10 23:33:40
Older post so OP may not see my reply, but FYI for others this guide works perfectly in Devuan for installing the fglrx drivers :
https://www.blackmoreops.com/2014/08/26 … dxk-linux/
