#1 2017-03-16 16:09:01
GNUser
[SOLVED] apt-file search not working
I use apt-file to find which package contains a given file. This is extremely handy and sometimes is the only way I know to get such information.
While apt-file works flawlessly in Debian Jessie, in Devuan Jessie apt-file cannot find what it needs to build its cache:
bruno@devuan:~$ sudo apt-file update
Ignoring source without Contents File:
  http://us.mirror.devuan.org/merged/dists/jessie/main/Contents-amd64.gz
  http://us.mirror.devuan.org/merged/dists/jessie-security/main/Contents-amd64.gz
  http://us.mirror.devuan.org/merged/dists/jessie-updates/main/Contents-amd64.gz
bruno@devuan:~$ apt-file search foo
E: The cache is empty. You need to run 'apt-file update' first.
Is this a problem on my end or is something missing from Devuan's repositories? It seems more likely to be the latter. If it's a repository problem as I suspect, does anyone know whether there are plans to add the missing "Contents Files" to Devuan's repositories? Thanks!
#2 2017-03-17 05:50:59
Re: [SOLVED] apt-file search not working
This is a known issue.
#3 2017-03-17 14:12:25
GNUser
Oops, my bad. Sorry for missing that.
#4 2017-03-17 23:32:35
No worries.  smile  Welcome to the forum btw!
#5 2017-03-18 15:17:26
GNUser
Thank you. I'm very happy to be part of this new community--it's truly an island of sanity. I have no interest in making my system orders of magnitude more complex so that I can (maybe) shave a few seconds off my boot time. When it comes to my OS, I'll take something I can more easily understand and control over something new and (supposedly) faster *anyday* smile Long live Devuan!
#6 2017-03-18 17:28:55
I was chrooting into an old wheezy installation to run apt-file until someone showed me these:
 To find what package a file comes from:
dpkg -S <file>
To find what files come with a package:
dpkg -L <package>
#7 2017-03-18 18:13:28
Could you possibly add that to your Package manager magic incantations?  And while you're there would be nice to have code tags around the commands.  wink
#8 2017-03-18 20:22:37
GNUser
Very nice, but has one drawback: "dpkg -S" can only search the contents of packages that are already installed on the system. If the purpose of the search is to determine which package to install, "dpkg -S" isn't going to help.
#9 2017-03-22 14:30:54
GNUser
Here's a robust workaround for the time being:
1. On a Debian Jessie system:
2. Copy /var/cache/apt/apt-file directory from Debian to Devuan
3. Copy /etc/apt/sources.list from Debian to Devuan, renaming it /etc/apt/debian-sources.list in Devuan so it doesn't conflict with Devuan's "real" sources.list
4. Put this in your ~/.bashrc:
alias apt-file='apt-file --sources-list /etc/apt/debian-sources.list'
Now apt-file searches work as expected, regardless of whether the package containing the file is already installed on your system or not. We're obviously searching through Debian's packages, but 99% of the time it'll be close enough. Just make sure to run apt-file as regular user, since regular user is the one who has the alias:
#10 2017-03-23 12:36:36
Thank you for that gem! I've been missing apt-file for a long time.
Slight modification: I didn't copy the cache file. I copied the debian sources.list to my user's home and ran 'apt-file -s sources.list update' and it put an apt-file directory in ~/.cache.
#11 2017-03-23 13:23:06
GNUser
Hats off, fsmithred. Your modification is much more elegant. Very nice.
#12 2017-07-26 05:04:27
Count_Cucaracha
Its robustness was short-lived as that option to apt-file no longer exists.
#13 2017-07-27 00:51:44
More information as to why not would be helpful.   Perhaps it was PEBKAC . . .
#14 2018-08-18 06:07:18
paulwratt
that "workaround" wont help, because it searches the contents of the copied apt-file caches and uses the Debian repos, NOT the Devuan repos and caches created from them.
https://dev1galaxy.org/viewtopic.php?id=2291
looks for "dir/Content-_arch_.gz" instead of "dir/binary-_arch_/Packages.gz"
Cheers
Paul
#15 2018-08-18 19:04:09
paulwratt
there is now a 100% solution, no patch needed the Devuan Jessie repos
EDIT: in fact after a quick check it turns out @golinux is right, there is no issue with the original script IF your repo points to deb.devuan.org:
https://dev1galaxy.org/viewtopic.php?pid=11397#p11397
#16 2018-08-18 20:00:21
If there is not already a bug report please submit one at bugs.devuan.org
#17 2018-08-19 13:48:20
paulwratt
I edited the other thread and the above post to reflect the situation.
