#1 2022-08-17 19:39:33
VH
Problem with Firejail and Chromium
Hello,
I have a problem with Firejail and Chromium.  I cannot type anything on it - on search bar, address bar, and even inside any webpage when I run it with firejail.  If I run it WITHOUT firejail, no problem.
When I first had that problem, I purged chromium, deleted personal files of chromium, reinstalled it, and it worked for a while.  Then again, it didn't work after a couple of weeks.  This time I did the same - purged and reinstalled - but it doesn't work anymore.
I am using Chimaera.
#2 2022-08-17 20:12:49
Re: Problem with Firejail and Chromium
Google +1. User privacy 0. This shouldn't come as a surprise . . .
#3 2022-08-17 21:49:20
VH
     Um, I don't understand what that means??
#4 2022-08-17 21:55:33
I can't use chromium in firejail either. Google has sabotaged disabling of certain "features". One of the best minds on the Devuan team, hasn't found a way to do it either. Perhaps someone else has the magic incantation . . .
#5 2022-08-18 05:43:35
Chromium doesn't need firejail, their seccomp-bpf sandbox is better and you can't run two sandboxes at once.
To get firejail to work try
chromium --no-sandbox
But it will decrease security.
