#1 2022-07-14 14:10:46
kyuss
Refracta Linux
Just installed the feb 2022 chimaera iso to a computer and everything working good except for one issue which i like to have available is the ability hide the firefox titlebar so i get a bit more screen real estate. I did the usual /customize firefox/ and click the checkbox titlebar. Any help much appreciated, i do notice also that gtk3 csd is not quite implemented on refracta, not sure how this done but the settings manager should be gtk3 csd look but is both xfce4 window and gtk3 csd?
Image:
#2 2022-07-14 14:32:53
Re: Refracta Linux
[completely off topic]
kyuss . . . I miss the 1970s! It's been all downhill since then . . .
#3 2022-07-14 14:44:27
kyuss
Re: Refracta Linux
I was a teenager in the 90's, i was not exposed to computers and smart communication as i am today, we relied on local telecom to contact eachother and that was usually a landline phone or a pay phone by the corner store. I just miss that life where facebook and social media was not a thing and we gathered together as a social group physically as friends and yet to be friends, no computers, no apps, no social conditioning etc. The smartphone imo has dumbed us all down. Not all but most.
#4 2022-07-14 15:16:07
Re: Refracta Linux
Refracta has a package installed to disable CSD. To undo that:
apt remove gtk3-nocsd
Also, there's a problem with the installer failing to undo a change that live-boot makes to anacron. You probably need to run the following commands.
# First make sure /usr/sbin/anacron.orig.anacron exists.
ls -l /usr/sbin/anacron*
# If you don't see anacron.orig.anacron, you don't need to run the following commands.
rm /usr/sbin/anacron
mv /usr/sbin/anacron.orig.anacron /usr/sbin/anacron
#5 2022-07-14 23:57:29
kyuss
Re: Refracta Linux
Thanks for that info, seems to have gotten rid of the gtk3 title bars. Unfortunate that xfce4 has gone the way of the gtk3 csd title bars on some of the apps though, its all mismatched.
#6 2022-07-15 00:32:40
Re: Refracta Linux
The Debian devs are "artistically challenged". It gets fuglier with each new release . . .
