#1 2022-06-19 15:18:43
xinomilo
Unknown
[SOLVED] devuan icon question
which icon package has devuan emblem (or something similar/alternative to debian-swirl.png) ?
looking for an alternative to /usr/share/icons/*/24*24/places/start-here.png
deepsea icon package is already installed, but it's not included there. (ceres).
so far i could only find a reportbug included svg (/usr/share/reportbug/devuan-emblem.svg) .
thanks in advance.
#2 2022-06-19 16:11:49
Re: [SOLVED] devuan icon question
Greetings xinomilo!
The graphics stuff is in gitea. The logos are here and scattered elsewhere in that directory.
#3 2022-06-19 16:25:46
Poke around in here:
https://git.devuan.org/devuan/documenta … t/graphics
Look in the logo directory and the numbered directories for the different releases.
Some of the icons are provided by the desktop-base package. That would include any icons used in the boot screen, the login screen and the icon for the applications menu in the xfce panel. All of them are archived in the documentation git I linked.
#4 2022-06-19 17:38:51
xinomilo
Unknown
thanks for the links, i already had the git repos cloned locally, just thought i asked for a package instead.. (devulcan.svg rocks btw smile )
deepsea start-here.png is actually the gnome icon, so i guess it's based on gnome-icon-theme(?)... just a suggestion, it could be replaced with devuan logo in devuan icon-themes for default usage by any other panel in devuan. (and iirc, some panels use /etc/alternatives/start-here* diversions, so that could also point to devuan logo instead.. )
anyway, another note to future "quests", there are more deepsea icons (= deepsea-icons-square-swoosh and deepsea-round-icons that are not included in official deepsea-icon package...) in https://git.devuan.org/devuan/documenta … ra-deepsea
thanks.
#5 2022-06-19 18:38:22
I just throw everything in git that I need to prepare the graphics for the themes. Some of them are not used in the actual theming.
#6 2022-06-19 19:40:23
Better Vulcan:
https://git.devuan.org/devuan/documenta … 64x480.png
And in case I ever fix the filename above, that link will change to the following...
https://git.devuan.org/devuan/documenta … 40x480.png
#7 2022-06-19 20:12:45
That was the grub splash for the first Devuan "Valentine" release in February 2015 just after Leonard Nimoy had died.
#8 2022-06-20 01:57:47
spcwingo
I know this is already marked solved, but I just thought I'd add my $0.02. This is the one I use for my menu:
https://upload.wikimedia.org/wikipedia/ … emblem.svg
#9 2022-06-20 03:16:22
For those who might be interested in the evolution of the Devuan logo and swoosh, here are the discussions mostly between hellekin and yours truly when we were creating the icon and logo in early 2015:
The idea starts here:
https://www.devuan.org/gitlab-issues/de … l#note_774
And finishes here:
https://www.devuan.org/gitlab-issues/de … ct.20.html
Thankfully, those germinal conversations were rescued from our old gitlab when we moved to gitea. smile
#10 2025-12-26 12:02:29
vrgovinda
git clone git@git.devuan.org:devuan-editors/devuan-art.git
Cloning into 'devuan-art'...
The authenticity of host 'git.devuan.org (116.202.138.212)' can't be established.
ED25519 key fingerprint is SHA256:mzdK5mml6/hHW6tLKzysmHhRdcQbvm4CwuD+hMf5kUA.
This key is not known by any other names.
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added 'git.devuan.org' (ED25519) to the list of known hosts.
git@git.devuan.org: Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
I'm sorry. I don't know much about how git works. Can someone tell me what is wrong?
know who you are and be who you are.
#11 2025-12-26 12:35:56
That which is wrong is that you are using a git clone URL as if you have set up your ssh authorising access for that project, which apperently you haven't.
The public cloning URL is https://git.devuan.org/devuan-editors/devuan-art.git
Try using that instead.
