#1 2022-06-09 19:07:09
deepforest
Ceres(5.18) legacy 340 nvidia driver not work
All working before kernel was updated to 5.18 So this legacy driver from Ceres repo not patched for this kernel?
smile
pyzNi 3.14zDa! smile
#2 2022-06-09 21:55:38
deepforest
Re: Ceres(5.18) legacy 340 nvidia driver not work
even this trick not works https://www.if-not-true-then-false.com/tag/debian/
Xorg log https://pastebin.com/raw/pC6yksyD
What is wrong with Ceres?
smile
#3 2022-06-09 22:05:11
What is right with ceres? It is "unstable" after all . . .
#4 2022-06-09 23:45:26
deepforest
Ok. For me all works normal until now. Both "unstable" Sid and Ceres, only this two deb based distros that bring me worked nvidia 340 drivers. But now something broken. How to fix?
smile
#5 2022-06-10 09:00:22
deepforest wrote:
How to fix?
Ask NVIDIA to stop being such a bunch of twats. Or buy a graphics card from a manufacturer that doesn't hate the open source community.
This is not a Devuan problem, it is an NVIDIA problem.
#6 2022-06-10 13:24:25
deepforest
deepforest wrote:
How to fix?
Before 5.18 all works and working on Fedora 36 but not on Ceres. Community patching drivers for new kernels. But now on Ceres drivers not working, why?
On Ceres this driver even installing with error now. On 5.17 all works.
Patched driver for 5.18 installed ok, but not starting.
This is problem of Debian or Devuan?
smile
#7 2022-06-10 15:30:30
deepforest
This trick is working
https://www.if-not-true-then-false.com/ … a-patcher/
you need add to xorg.conf this lines to working
Section "ServerFlags"
    Option "IgnoreABI" "1"
EndSection
This is Debian issue
smile
#8 2022-06-10 16:00:59
Not really. Even if you are correct the proprietary drivers are not part of the official distribution.
#9 2022-06-10 16:06:59
deepforest
So Devuan issue? I have error("driver not installed") after installing 340 driver from Devuan Ceres repo on 5.18. On 5.17 all installing and works good.
smile
#10 2022-06-10 16:22:32
The proprietary drivers are not part of the official Devuan release either.
#11 2022-06-11 01:28:18
deepforest
Why? Devuan not supported any proprietary drivers!?
ps in my case, 340 is still supported bu Debian Sid, or i am wrong? Sid been supported 340 untill 5.17, what happend now?
smile
#12 2022-06-11 03:52:33
brocashelm
Correct, this has to do with the GPU and its manufacturer's disdain for the open-source community. Even Intel contributes to them.
This has nothing at all to do with whether or not you're using the unstable versions of either Debian or Devuan. Some workarounds exist, but are not foolproof.
Have a video:
https://www.youtube.com/watch?v=iYWzMvlj2RQ
#13 2022-06-11 10:58:43
Because the source code is not available. The drivers are available from the non-free component of the repositories as a convenience for users but that component is not considered part of the official release.
#14 2022-06-11 11:58:04
deepforest
and what? nvidia have linux driver that patched by community for new kernels. so its devuan or debian issue that it not apply patched diver in his repo.
smile
#15 2022-06-11 12:31:25
Devuan aren't going to patch the kernel to fix a problem introduced by NVIDIA. That would be ridiculous.
#16 2022-06-11 13:17:48
deepforest
Problem already fixed https://aur.archlinux.org/packages/nvidia-340xx
Devuan or Devian devs must just add it to repo
ps for me working this solution https://www.if-not-true-then-false.com/ … a-patcher/
smile
#17 2022-06-11 13:25:35
And I'm sure they will. Eventually.
Starting threads here and over at forums.debian.net will not get the attention of the NVIDIA driver Debian maintainers and it will not speed the update in any way. In particular forums.debian.net is almost entirely a user-based forum with very few Debian developers visiting.
