#1 2022-05-26 15:00:44
James1138
Question about upgrade kernel
I am using Devuan 10 (Buster) with kernel 5.10.0-0.bpo.12-686-pae - but Debian repository shows newer kernels such as linux-headers-5.10.0-13-686-pae. Would it be safe to upgrade kernel using those seen in Debian 11 (Bullseye)?
James
Indiana
#2 2022-05-26 15:42:16
Re: Question about upgrade kernel
Don't mix up kernels (linux-image) with kernel headers (linux-headers).
You should not consider mixing distros.
My suggestion is to consider upgrading to Chimaera.
#3 2022-05-26 16:25:10
There is no Devuan 10. Devuan Releases are listed HERE.
#4 2022-05-26 16:52:03
You are right, overlooked that.
