#1 2022-04-17 19:32:12
ndavilam
[SOLVED] Existential doubt
If DEVUAN walks parallel with Debian bullseye, why doesn't the same thing happen with DEBIAN testing/unstable y Daedalus/Ceres?
#2 2022-04-17 19:37:30
Re: [SOLVED] Existential doubt
It does.
The canonical answer is here:
https://www.devuan.org/os/releases
And here:
https://files.devuan.org/ (or from your favorite mirror)
#3 2022-04-17 19:49:20
ndavilam
Thanks for your quick answer.
If I wanted to update Devuan with kernel 5.16, is there currently a repository with this package?
golinux wrote:
It does.
And here:
#4 2022-04-17 19:59:17
Daedalus /ceres
#5 2022-04-17 20:04:12
ndavilam
rolfie wrote:
Daedalus /ceres
Thanks, my confusion started when I read the kernel information that comes in Daedalus in Distrowatch
sorry for my lack of information
#6 2022-04-17 20:26:40
Also check backports to see if it might be there.
#7 2022-04-18 09:33:53
alexkemp
I'm running Chimaera with backports & kernel is 5.16:
$ grep -h ^deb /etc/apt/sources.list /etc/apt/sources.list.d/*
deb http://deb.devuan.org/merged chimaera-security main non-free contrib
deb http://deb.devuan.org/devuan chimaera-proposed-updates main non-free contrib
deb http://deb.devuan.org/merged chimaera-backports main non-free contrib
$ uname -r
5.16.0-0.bpo.4-amd64
You will notice the 'bpo' within the kernel name, which indicates that it's origin is "backports".
