#1 2022-03-14 08:32:22
ferozfirru
How can we get Parent release name in devuan , for example Bullseye?
hello guys,
Devuan chimaera is based on debian bullseye right, is there anyway to get this "bullseye" text from any file?
im unable to find it, only chimaera showing everywhere
#2 2022-03-14 09:54:18
xinomilo
Unknown
Re: How can we get Parent release name in devuan , for example Bullseye?
look at : /etc/debian_version
its included in base-files package, along with /etc/devuan_version
#3 2022-03-14 13:04:15
ferozfirru
thanks for the reply mate,
but no luck
abcde@fersys:~$ cat /etc/debian_version
11.1
abcde@fersys:~$ cat /etc/devuan_version
chimaera
#4 2022-03-14 18:05:26
xinomilo
Unknown
seems that's only in bullseye/stable and only for debian_version. devuan_version shows chimaera.
in testing/ceres i get release name :
/etc/debian_version :
bookworm/sid
/etc/devuan_version :
chimaera/ceres
edit] hm, chimaera should be daedalus, no?
#5 2022-03-14 18:09:24
Yes.  bookworm will be excalibur
#6 2022-03-15 04:26:17
ferozfirru
thanks im just aksing if the devuan developers had placed this "bulleye" text anywhere in the system or not.
#7 2022-03-15 11:28:53
Not sure if this is a Devuan topic. I guess this file is a copy of the corresponding file from Debian. Just verified with a Bullseye installation in my VBox. There I also get 11.2.
#8 2022-03-15 13:02:09
In my daedalus install, /etc/debian_version says "bookworm/sid". I think they switch to numbers when it goes stable, so it shows which point-release you are at.
