#1 2022-02-09 07:06:23
SpongeBOB
[SOLVED] Login screen appear after 4 min after setting nftable rules.
Hi everyone,
I just installed nftable on my system (thanks to Head_on_a_Stick )
Now,when I edit the
default /etc/nftables.conf
#!/usr/sbin/nft -f
flush ruleset
table inet filter {
         chain input {
                   type filter hook input priority 0;
         chain forward {
                   type filter hook forward priority 0;
         chain output{
                   type filter hook output priority 0;
to
#!/usr/sbin/nft -f
flush ruleset
table inet filter {
         chain input {
                   type filter hook input priority 0; policy drop;
         chain output{
                   type filter hook output priority 0; policy drop;
I reboot then my screen is black for 4Min 24Sec before I finally see the login screen.
When I do a /user/sbin/nft -f /etc/nftables.conf the rule apply with no delay.
so I guess something at boot is conflicting with this ruleset, but what ?
Thanks.
#2 2022-02-10 05:41:09
SpongeBOB
Re: [SOLVED] Login screen appear after 4 min after setting nftable rules.
Same behavior when I logout, ~4min before I can see the login screen 😭
#3 2022-02-10 06:12:31
SpongeBOB
I made few test and this issue occur if
chain input {
or / and
chain output{
has/have policy set to drop...
#4 2022-02-10 06:35:50
SpongeBOB
/var/log/slim.log wrote:
slim: waiting for X server to shut down
slim: waiting for x server to begin accepting connection
slim: Consolekit::open_session: unable to open session: The name org.freedesktop.ConsoleKit was not provided by any .service
slim: falling back to PAM session
#5 2022-02-10 10:11:17
hevidevi
maybe just copy over the worksation.nft to /etc/nftables.conf from /usr/share/doc/nftables/examples/workstation.nft
backup your original nftables.conf before you do this.
#6 2022-02-10 16:02:03
^ +1
@OP: what are you trying to achieve with that configuration? It will not be possible to connect to the internet unless you allow tracked connections, like this:
    ct state {established, related} accept
And the loopback device will also be blocked without
    iifname lo accept
I suspect the delay is due to either the loopback or internet block, check /var/log/messages for anything relevant.
#7 2022-02-11 05:18:52
SpongeBOB
Hi HOAS,
Thanks for your reply,
... @OP: what are you trying to achieve with that configuration?
This is not my final config, but the start. Excluding everythings then make some exceptions. (opening only the necessary)
indeed I plan to add something like ct state {established, related} accept
    iifname lo accept
Hoo that I didn't think about it !! thx !
I will make make some tests and I will update this topics in the following hours.
Thanks again.👍
#8 2022-02-11 07:53:15
SpongeBOB
Still the same issue with
nft list ruleset
table ip6 Tip6 {
         chain chPR{
                   type filter hook prerouting priority filter; policy drop;
table ip Tip {
         chain chIN{
                   type filter hook input priority filter; policy drop;
                   ct state established,related accept
                   iifname "lo" accept
on the other hand
table ip Tip {
         chain chIN{
                   iifname "lo" accept
work !, but WHY slim would require IPv6 🤨 ?
I've cleared /var/log/messages before testing, and nothing generate new messages.
#9 2022-02-11 17:38:40
SLiM is ancient, unmaintained and it doesn't support login sessions correctly. It probably has several other bugs as well thanks to 8 years of code rot.
Do you still experience the delay with (for example) GDM? How about a plain console login?
#10 2022-02-14 05:49:05
SpongeBOB
Thanks HOAS,
I didn't tried yet, talking about display manager aka login manager, does someone have any recommendation for one that work well with devuan ? That is gpl ? and lightweight ?
I edited the grub command at boot with key e ->
and added 3 at the end of the line Linux  /boot/vmlinuz..... but this is not working -> it launch slim still.
So I tried with the option: Advanced options for devuan GNU/Linux then (recovery mode) that option have no delay to login with console. But I guess in that mode a lot of services are down ?
How can I login (normally 5) in console without Slim ?
#11 2022-02-14 06:03:48
SpongeBOB
To be able to boot in console I have just done a apt purge slim big_smile
So I can confirm the delay problem was coming indeed from Slim.
#12 2022-02-14 17:32:24
I am using lightdm with Mate or Cinnamon, no issues, uses elogind.
#13 2022-02-14 17:48:22
LightDM runs X under the root user but GDM or console logins run X under the normal user, which is *much* better.
To start the graphical desktop automatically after login at TTY1 add this line to the end of ~/.profile:
[ "$(tty)" = /dev/tty1 ] && exec startx
We don't need no stinkin' display manager...
#14 2022-02-14 18:55:49
There is comfort and beauty (sometimes) in a display manager.  big_smile Art matters . . .
