#1 2021-10-18 18:51:29
kenunix
Devuan on Virtualbox share not working
After installing Devuan as a guest on virtualbox I can not get "share" to work.
Thanks.
#2 2021-10-18 19:07:56
Re: Devuan on Virtualbox share not working
Not a Devuan problem. What exactly do you want to achieve, and what have you done as preparation?
#3 2021-10-18 19:22:58
kenunix
Installed Devuan 3.0 on Virtualbox 6.1.26
Made guest additions
Mouse and Video working well
"shares" not working. Not showing up
They show up on other guests
Thanks
#4 2021-10-18 19:38:00
You have to define the shared folder in the VBox Manager and then you need to mount it within Devuan. Refer to VBox manual.
#5 2021-10-18 19:58:29
kenunix
It is configured in Virtualbox under guest (Devuan 3.0) / shared folders.
As I said this works on other guest systems.
#6 2021-10-19 00:28:38
devadmin
I've just installed devuan from netinstall on Vbox. All share folders work fine:
in guest:
apt-get install build-essential module-assistant
m-a prepare
In my case headers were installed on this step
Attached guset cd, then
mount /media/cdrom
sh /media/cdrom/VBoxLinuxAdditions.run
lsmod | grep vboxguest
if everything is ok, then
adduser <vm_guest_user_name> vboxsf
Done
#7 2021-10-19 00:45:22
kenunix
What version of Devuan are you running on what version of Virtualbox.
I did actually what you laid out. No go. The version of Devuan I installed is Devuan beowulf 3.0 323mb.
#8 2021-10-19 00:50:50
devadmin
I installed chimaera on 6.1.26 r145957 virtualbox.
#9 2021-10-19 00:53:34
devadmin
and declared path to shared f. in Vbox itself with automount option. No changes in guest's fstab
#10 2021-10-19 00:57:18
Just curious why not beowulf 3.1.1.  Of course with a full upgrade you would eventually get there.
#11 2021-10-19 15:12:25
kenunix
Thanks for your help. devadmin's procedure worked. It must have been the netinstall.
My reasoning for 3.0 was to get and older release to verify special software on.
Ken
