#1 2021-08-22 14:02:14
mu
[SOLVED] Security question about Devuan 4 in its current state
Debian posts warnings about using testing with regard to security.
https://wiki.debian.org/Status/Testing
says "... If you want to have a secure (and stable) server you are strongly encouraged to stay with stable."
Would that apply to running Devuan 4 at this point in its development cycle?
#2 2021-08-22 15:11:29
Ogis1975
Re: [SOLVED] Security question about Devuan 4 in its current state
            ----+- Peter Kropotkin -+----
#3 2021-08-22 15:17:00
Debian testing is now "Bookworm" which will be the base for Devuan 5 "Daedalus".
Devuan 4 "Chimaera" is based on Debian "Bullseye" which is now stable.
Note that if you use "testing" in your sources.list, you will find yourself upgraded to "Bookworm"/"Daedalus" which is basically Ceres at this point.
#4 2021-08-22 17:19:54
mu
Thank you. I have installed Devuan from the chimaera_4.0.beta-20210816_amd64_netinstall iso and so far it is working great for me. I plan to just stick with it. My sources.list just points to the chimaera repos.
Will it eventually just morph into the release by doing the updates?
#5 2021-08-22 18:46:34
Yes. And it's almost there. The desktop theme is still partly broken and there may still be some bugs in the installer isos. I don't think there's much else that needs to be done. Oh yeah. Write the docs.
