#1 2021-08-20 17:51:16
zeitlos
Systemd folder
Dear developers! How can you explain the fact that your distribution has a Systemd folder (/etc/systemd)? What is it for if by default Devuan comes without Systemd?
#2 2021-08-20 17:56:35
zeitlos
Re: Systemd folder
And one more question. Why are "non-free" repositories initially connected? Are there only "free" branch repositories?
#3 2021-08-20 18:06:48
Re: Systemd folder
Welcome to the forum.
Your question is answered in this sticky post:
Why are systemd files present in Devuan?
#4 2021-08-20 18:12:34
Re: Systemd folder
That is so users can actually install Devuan. You can avoid non-free firmware by following this advice in the Install Guide:
If you would like to select an alternate bootloader (lilo) or exclude non-free firmware, you must choose "Expert install" under Advanced options.
#5 2021-08-20 18:26:13
zeitlos
Re: Systemd folder
Yhank you for fast answers.
