#1 2021-07-19 12:20:36
sgage
Amprolla behavior when bullseye released
In the interim between Bullseye's release as 'stable' and Chimaera's release, what does amprolla do to generate the chimaera 'virtual' repo? Does it continue merging from bullseye? Or does it start merging from the new Debian testing (bookworm)? What does it do for ceres in this interim? Will it merge from bookworm, or always continue merging from sid?
#2 2021-07-19 12:38:26
Re: Amprolla behavior when bullseye released
Bullseye = Chimaera
Bookworm = Daedalus
That's why it is a bad idea to use "testing" in your sources.list.
#3 2021-07-19 13:01:13
sgage
So amprolla always merges according to the 'matching' Debian version, and doesn't really care about stable vs. testing. And ceres will always track sid. I was just curious about the interim period.
Since I started with Devuan back in Jessie days, I've never used stable, testing, etc. in sources.list. That was made very clear from the get-go!
