#1 2016-12-06 15:55:11
New Purpy forum skin
As per @xunilog's request, I have added a Purpylite skin to the available themes.  The code boxes in that theme are now dark font on light gray.   Feedback welcome!
#2 2017-06-22 15:08:55
mckaygerhard
Re: New Purpy forum skin
i alway said the meaning of "contrast" its strong agains soft, not soft agains soft but at leas users can change the look when login in the forum..
I bet that if you survey how many users change the main theme you will find a big surprise, maybe forum need to make a survey to see it users real opinion..
#3 2017-06-22 21:34:41
Whilst I agree on the idea that strong contrast is better, a glance at the forum style usage rather shows that most people (88%) find the default anywhere on the scale from pleasant to  sufficiently acceptable, to not bother to change.
#4 2017-06-23 03:35:01
pekman
In my opinion, there is no problem with the appearance of the forum.
But we could make a black theme to be used as an alternative
#5 2017-06-23 03:48:06
No need to do that.  There are already three black themes available under user profile.  wink
#6 2017-06-23 04:17:11
pekman
Very impressive. Congratulations
#7 2017-06-23 04:44:18
Oh, I had nothing to do with that.  They were part of the default FluxBB install.  I only did the two purpy themes.  wink
#8 2017-06-23 16:11:15
Somewhat Reticent
golinux wrote:
…There are already three black themes available under user profile.  wink
None using purple/lavender … all using shades of white.
There's certainly room for cool creativity (should the energy be available, and seeking an outlet … in an acceptable direction).
