#1 2021-06-18 16:37:29
joachin
[SOLVED] need help to add mi user to sudoers.
Hello, I have some troubles trying to add my user to the sudoers group, every time that I try to do so, I receive the following message: "gpasswd: group 'wheel' does not exist in /etc/group". Additionally, could you please help me since the key to mute/unmute the microphone is not working on XFCE, do you know the command to add the shortcut?
Thank you.
#2 2021-06-18 16:45:59
dice
Re: [SOLVED] need help to add mi user to sudoers.
you need to add it the sudo group.
# gpasswd -a joachin sudo
#3 2021-06-18 16:52:34
joachin
I have already done so, and also edited the sudoers file, reboot and every time that I want to use the command, i receive the following message:
sudo apt update
[sudo] password for joachin:
joachin is not in the sudoers file.  This incident will be reported.
#4 2021-06-18 16:54:32
I suggest you start a new thread for you audio issue.
#5 2021-06-18 17:06:30
joachin
Sure, I will open a new ticket for the audio issue. Thank you.
#6 2021-06-18 17:52:14
Can we see the output of these commands from your normal user:
sudo -l
groups
#7 2021-06-18 19:47:54
joachin
Hello there, this is the output of these commands:
sudo -l
Sorry, user joachin may not run sudo on joachinlaptop.
the second one:
groups
joachin cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
#8 2021-06-18 20:40:18
How about
getent group sudo
Please also share the full content of /etc/sudoers and any files under /etc/sudoers.d/.
#9 2021-06-18 21:29:50
joachin
Hello there, I don't know what happened, but now all it's working as expected. I really appreciate your help.
