#1 2021-05-10 17:42:16
anon
Creating a Custom Devuan Iso with Preinstalled Packages
I was wondering how I would go about creating a custom devuan iso that comes with packages of my preference out of the box (window manager, cmd utilities etc) so that I don't have to configure anything myself.  The reason I want to do this is to have a perfect copy of my system that I can reinstall in case anything happens to my computer, I also want to be able to share this ISO with my friends so that they can also try my pseudo-distro.  I looked around and found a way to do this in debian using an utility called
live-build
but I don't know if this would work in devuan.  I also found this blog post that addresses the exactly what I want to do but it's from 2015 and it's meant for devuan jesse.  Should I just make a custom debian iso and then devuan-ise-it using this guide. Or is there a way to do this natively?
I don't know if this matters but I plan on installing the following packages in the devuan iso:
  • Dwm Window Manager
  • Vim with my own config
  • Python Packages
  • Gtk & Qt Themes
  • St Terminal
  • Picom compositor
  • Other small packages e.g. youtube-dl cmus etc
hey
#2 2021-05-10 18:08:18
Re: Creating a Custom Devuan Iso with Preinstalled Packages
refractasnapshot.  Devuan "live" installation isos are created using it.  It's in the repos and more info at refracta.org
#3 2021-05-13 16:00:08
MiyoLinux
#1 ^
Except you should use MOC instead of CMUS. Hahahaha! tongue
#4 2021-06-13 19:19:50
lightwaves
I've used systemback 2.0 with beowulf. has worked with lxde, xfce and plasma using beowulf. peace love light
Sometimes refracta does not work from the repos, though probably just me not installing something else needed, though systemback 2.0 is nice.
#5 2021-06-14 15:05:46
Ogis1975
anon wrote:
Picom compositor
This program does not exist in Devuan Beowulf repos
            ----+- Peter Kropotkin -+----
#6 2021-06-14 15:41:55
Nili
picom exists on Devuan testing/sid repo for the moment.
https://pkginfo.devuan.org/cgi-bin/poli … ge&q=picom
as it in Debian testing/sid too only.
https://packages.debian.org/search?suit … ords=picom
To have it on Devuan, one must enable testing/sid repo, but (keep in mind these are for test or guts smile)
From my testing:
root@devuan:/home/user# apt-get install -s picom
  libconfig9 libev4 libxcb-composite0 libxcb-damage0 libxcb-image0 libxcb-randr0 libxcb-render-util0 libxcb-xinerama0
  libconfig9 libev4 libxcb-composite0 libxcb-damage0 libxcb-image0 libxcb-randr0 libxcb-render-util0 libxcb-xinerama0 picom
0 upgraded, 9 newly installed, 0 to remove and 0 not upgraded.
Inst libconfig9 (1.5-0.4 Devuan:4.0.0/testing [amd64])
Inst libev4 (1:4.33-1 Devuan:4.0.0/testing [amd64])
Inst libxcb-composite0 (1.14-3 Devuan:4.0.0/testing [amd64])
Inst libxcb-damage0 (1.14-3 Devuan:4.0.0/testing [amd64])
Inst libxcb-image0 (0.4.0-1+b3 Devuan:4.0.0/testing [amd64])
Inst libxcb-randr0 (1.14-3 Devuan:4.0.0/testing [amd64])
Inst libxcb-render-util0 (0.3.9-1+b1 Devuan:4.0.0/testing [amd64])
Inst libxcb-xinerama0 (1.14-3 Devuan:4.0.0/testing [amd64])
Inst picom (8.2-1 Devuan:4.0.0/testing [amd64])
Conf libconfig9 (1.5-0.4 Devuan:4.0.0/testing [amd64])
Conf libev4 (1:4.33-1 Devuan:4.0.0/testing [amd64])
Conf libxcb-composite0 (1.14-3 Devuan:4.0.0/testing [amd64])
Conf libxcb-damage0 (1.14-3 Devuan:4.0.0/testing [amd64])
Conf libxcb-image0 (0.4.0-1+b3 Devuan:4.0.0/testing [amd64])
Conf libxcb-randr0 (1.14-3 Devuan:4.0.0/testing [amd64])
Conf libxcb-render-util0 (0.3.9-1+b1 Devuan:4.0.0/testing [amd64])
Conf libxcb-xinerama0 (1.14-3 Devuan:4.0.0/testing [amd64])
Conf picom (8.2-1 Devuan:4.0.0/testing [amd64])
sid repo...
deb http://deb.devuan.org/merged sid main non-free contrib
or, wait until testing becomes stable as it will end on stable sooner or later.
openSUSE Tumbleweed KDE/Wayland
♫♪ Elisa playing...
Damascus Cocktail ♪ Black Reverie ♪ Dye the sky.
