#1 2021-04-20 12:36:08
Dutch_Master
Beowulf is broken
ASCII -> Beowulf upgrade
boot option: Qemu/Xen enabled
# whoami
root
# uname -a
Linux desktop 4.19.0-16-amd64 #1 SMP Debian 4.19.181-1 (2021-03-19) x86_64 GNU/Linux
# echo $PATH:
/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
# modprobe -c
bash: modprobe: command not found
# halt
bash: halt: command not found
WTF! >:-{
#2 2021-04-20 12:40:02
dice
Re: Beowulf is broken
modprobe and halt are in /sbin/ so not on your $PATH by the looks of it, not broken just missing input.
edit: for my roots $PATH atleast i have /sbin/
root@beowulf:~# $PATH
-bash: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:
#3 2021-04-20 12:46:51
Dutch_Master
In that case, during the upgrade this new directory should have been added to $PATH for root, but clearly it hasn't on my system. Or it was removed by the upgrade, that I can't be sure of as I didn't test it before upgrading.
[edit] Found the culprit, in /etc/profile:
if [ "`id -u`" -eq 0 ]; then
  PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
else
  PATH="/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games"
fi
export PATH
So, if the user uses su into root from your normal user, the id does not equate to 0 thus /sbin is not in your $PATH roll
PS: which "bright spark" had the "luminous" idea to set terminal text as bright yellow on a bright white background? You should be clobbered into sense with a foam bat! roll
#4 2021-04-20 12:56:04
dice
Im not 100% certain but i believe this might be due to the UsrMerge scheme adopted by debian. I always choose not to merge during installation.
https://wiki.debian.org/UsrMerge
#5 2021-04-20 13:01:58
Dutch_Master
Regrettably, that wasn't an option during my upgrade.
#6 2021-04-20 13:05:21
su got moved from shadow to util-linux. I don't know what thought went into the change in root's path when you get there via 'su'. If you use 'su -' it still works the same as it used to. It's in the release notes for beowulf along with some other inherited gems and workarounds. https://files.devuan.org/devuan_beowulf … _notes.txt
#7 2021-04-20 13:07:28
dice
ahh just saw your edit: always use su - due to this bug report. https://bugs.debian.org/cgi-bin/bugrepo … bug=918754
#8 2021-04-20 13:10:29
Dutch_Master
OK, fair enough. I don't use su -, I created an alias for su to invoke su - in ~/.bash_aliases. It works, but clearly not for everything.
#9 2021-04-20 15:03:02
I hate using 'su -'. Most of the time when I become root, I'm already in the directory where I want to do stuff, and I want to stay there. I don't want to change to /root. And sometimes I want to run a graphical app as root from the user's desktop. That got lost in the change, too. Fortunately, there's a way to restore the old behavior.
ALWAYS_SET_PATH yes
in /etc/default/su
#10 2021-04-20 16:59:21
Dutch_Master
Yeah, I did that too now. Didn't solve all issues, I still can't load a module required for Qemu. As root:
# echo $PATH
# modprobe kvm-amd
modprobe: ERROR: could not insert 'kvm_amd': Operation not supported
# modprobe kvm_amd
# modprobe -c | grep kvm_amd
alias cpu:type:x86,ven*fam*mod*:feature:*00C2* kvm_amd
So, what next?
#11 2021-04-20 20:13:37
Dutch_Master
Well, for the 2nd time tonight Beowulf crashed. I was browsing while playing 2 local video files (via smplayer and vlc respectively) and it froze solid. No input, audio looped continuously, no response at all. Only a hard reset could solve the issue. This was on the Xen-enabled kernel. On ASCII, this scenario was perfectly fine and it could do this literally all day and never miss a beat. Now running the non-Xen kernel, see if that changes anything.
So far, Beowulf impresses me badly for all the wrong reasons roll
#12 2021-04-20 22:12:36
fsmithred wrote:
... hate using 'su -'. Most of the time when I become root, I'm already in the directory where I want to do stuff, and I want to stay there.
Ahh ...
And I thought I was the only one.  8^D
I'm trying hard to get use to su - and how it works.
Sometimes I fear that not being where I want to be (and in /root instead) will make/allow me to do something stupid.
fsmithred wrote:
... there's a way to restore the old behavior.
ALWAYS_SET_PATH yes
in /etc/default/su
But you still have to use su -, you just don't get sent to /root.
Right?
#13 2021-04-20 22:29:23
Ahh ...
ALWAYS_SET_PATH yes
in /etc/default/su
Right?
ahh, no. I thought I was the only one! Funny, not funny.
I have nothing to add, except the ufw program complains when trying to start that user ID is 1000 when 0 is expected. Which I think may be a similar problem to the above, so I'm following this thread. Thank you.
#14 2021-04-20 22:44:16
Dutch_Master
My experience is, so far, that adding the set_path option in /etc/default/su outlined above works and su reverts to it's normal, expected behaviour. So, I can obtain root with a simple su, no extra dash required, and I stay in the current dir too!
#15 2021-04-21 04:13:33
My appologies, I posted a reply, but I was wrong, so I deleted it... just rubish.
I had intended to creat the file /etc/default/su with the content ALWAYS_SET_PATH yes, but all I did was paste in the file address instead of the command. :'-(
Sorry for the bumb steer.
#16 2021-04-22 22:44:59
Dutch_Master
Well, after one too many freeze up I ditched Beowulf, tried to get Funtoo to work (but a core package for Mate failed to configure repeatedly and consequently build) then late last night I took my ASCII USB stick and booted from it. Installed ASCII, but sadly, the random freezes are still there. It might be related to Firefox, may need to look into that.
So, not a happy chappy here, to say the least >:-{  I may try Mint, but that means [shudder] systemd :puke:
#17 2021-04-22 22:57:07
Maybe a hardware issue?
#18 2021-04-22 23:05:45
have you tried a decent memtest?
#19 2021-04-22 23:25:29
Dutch_Master
Yes, I did. Unless it's deteriorated incredibly fast in the past weeks, I doubt that'll be a problem (it's been in the system for years and never failed, even with the intensive use I require from it)
#20 2021-04-22 23:50:22
All things are impermanent.  smile
#21 2021-04-23 12:16:24
ALWAYS_SET_PATH yes
in /etc/default/su
Right?
After making the edit:
Use su -if you want to cd to /root.
Use su if you want to stay in the current directory or if you want to run a graphical app as root on the user's desktop. (e.g. I frequently start gparted from terminal because I'm already in a terminal and it's easier than going up to the menu.)
@Dutch_Master: check to see if your cpu or motherboard is known to freeze with linux. I have one box that needs an extra boot option to prevent lockups.
#22 2021-04-23 13:28:42
Dutch_Master
I'm pretty sure it's not the mainboard, as that's been running stable for the past 6 years. Before my unfortunate "upgrade" to Beowulf, the CPU I'd put in last month was also stable. Both are fairly old so should be supported in Linux. So, I'm suspecting a remnant of Beowulf config somewhere as I've re-installed ASCII again this morning, after I removed a number of no-longer used dot files/folders in my users home dir. So far it hasn't locked up on me. See how long that lasts.
Come to think of it, it could be related to power management and/or screensaver stuff instead. I have the screensaver turned off and the power management switched off to the maximum intent, but after a period of no user input (mouse, kb), the screen still blanks itself (which is probably inside the monitor). I need to look that up and see if I can counter this behaviour (IIRC there was a kernel option to disable it, not sure)
(PS: for those who want to look it up, the mainboard is a Gigabyte F2A88XM-D3H with BIOS version F8, CPU is an AMD APU: PRO A10-8750B, no separate discrete GPU)
#23 2021-04-26 17:54:09
Dutch_Master
Well, 3 days on, no lockups. It seems the culprit was indeed some stray Beowulf config that got blasted when I re-installed ASCII. Good riddance!
Next step: see if AQemu works, despite the IOMMU BIOS setting being disabled by default. Goal: run Win7 as VM.
#24 2021-05-25 20:13:11
garyk
I suppose that's one possible answer, but I have the same problem on Ceres.  If I try to run two different videos at the same type my system freezes solid.  The only way out is to press and hold down the power off button.  That's not a good option.
#25 2021-05-25 20:47:23
andyprough
Are you streaming the videos on wifi? I had wifi related lockups on MX and Devuan, and fixed them by turning off USB Autosuspend in tlpui. Clearly tlp was not playing nice with my wifi card. Just figured I would throw that out there.
If it's not wifi related or some setting in tlp, feel free to share how you are watching the two videos when the lockup happens. I can try to recreate it on my antiX Sid install, maybe we'll find it's some wayward Sid package that's causing the lockups.
