#1 2021-03-09 18:00:30
alphalpha
[Solved] Dev1Galaxy Login Problem (Palemoon)
Hello everyone,
i have problems to login to this forum when i use the palemoon browser,
i dont have this problems on other websites or with another browser
(ublock origin / ematrix  is disabled)
it says "Logged in successfully. Redirecting ..."
but then i get back to the page where i was and i am not logged in
greetings
#2 2021-03-09 18:29:12
Re: [Solved] Dev1Galaxy Login Problem (Palemoon)
I use palemoon to access this forum but then I am always logged in with a window open.  Have you cleared cookies, cache and history?  That might be a good place to start.
#3 2021-03-10 10:02:18
Geoff 42
I also use Palemoon. I have this forum permanently open in a tab, but only log in as required and have just logged in to post this.
Geoff
#4 2021-03-10 11:28:52
I also use Palemoon for this forum and have no probs, I also use eMatrix blocker.
turn eMatrix off while you check. Once you have it working turn eMatrix back on and set it up so you get no interference.
It's probably a cache issue...
#5 2021-03-10 19:22:57
alphalpha
okay, i just found the problem
the eclipsed moon Addon has to be disabled
#6 2021-03-10 19:29:18
Excellent.  Please mark this thread as solved.
