#1 2021-02-12 04:06:16
ruenoak
Gemini protocol
Hi all,
I have recently discovered a new Internet protocol called Gemini. https://gemini.circumlunar.space/ A sort of a modern take on the Gopher protocol. As a lover of text and minimal design, it's a breath of fresh air from the migraine the Web gives me every time I open a browser these days.
Just wondering what the thoughts of the community are on Gemini.
A Gemini site is called a capsule.
Here is my Capsule
gemini://cratermouse.com Gemini client needed
https://portal.mozz.us/gemini/cratermouse.com/ http portal
All the best
ruenoak
"Has cat, eats cheese, drinks coffee, Chaotic Neutral " smile
#2 2021-02-12 04:25:03
Re: Gemini protocol
I LOVE the Gemini project.  Devuan is well familiar with this project and gopher also.  Thanks for bringing it to the attention of our forum users.
#3 2021-02-12 14:43:31
andyprough
Re: Gemini protocol
I'd like to get a recommendation for a gemini client. There's a huge number of them, and I don't want to waste a lot of hours trying them all out. Is there one that's reasonably easy to install on Devuan and that works reasonably well? Looks like Castor may be the one to try first, but I figured I'd ask your opinion since you are more familiar with Gemini.
#4 2021-02-12 15:19:23
dice
Re: Gemini protocol
@ andyprough, what about the dillo browser plus plugin.
https://portal.mozz.us/gemini/celehner. … lo-gemini/
#5 2021-02-12 15:20:22
yeti
Re: Gemini protocol
Elpher.
#6 2021-02-12 15:41:21
Re: Gemini protocol
Drew DeVault has one: https://git.sr.ht/~sircmpwn/gmni
Looks pretty simple to install manually. I can make up a package for it if you want.
More options here: https://gemini.circumlunar.space/clients.html
#7 2021-02-12 16:18:43
dice
Re: Gemini protocol
that wouldnt build for me.
if you follow the compile instructions i was left with.
make: *** No targets specified and no makefile found.  Stop.
Instruction.
$ mkdir build && cd build
$ ../configure
$ make
# make install
openssl not found.
~/gmni/build $ ../configure
Checking for -g... yes
Checking for -std=c11... yes
Checking for -D_XOPEN_SOURCE=700... yes
Checking for -Wall... yes
Checking for -Wextra... yes
Checking for -Werror... yes
Checking for -pedantic... yes
Checking for OpenSSL... NOT FOUND
Tried pkg-config libssl
#8 2021-02-12 17:00:33
Re: Gemini protocol
Try
# apt install libssl-dev
EDIT: corrected advice.
#9 2021-02-12 21:36:44
andyprough
Re: Gemini protocol
I'm trying out a gemini browser called "Lagrange". It's got a .deb installation file available as part of a Debian Buster zip download: https://git.skyjake.fi/skyjake/lagrange … tag/v1.1.0
It has a few gemini sites bookmarked, and has a little search engine for searching some gemini sites worth visiting. I found ten pages (or "capsules") that mention Devuan. Seems to work very fast. Not a whole lot of content to look at right now.
#10 2021-02-12 22:20:06
Re: Gemini protocol
gmni package here: https://software.opensuse.org//download … ckage=gmni
@OP: I like your capsule but EMACS? Really? #vimftw tongue
#11 2021-02-13 02:01:45
ruenoak
Re: Gemini protocol
@andyprough. I'm using Kristall nightly and elpher in Emacs both are Appimages so it depends on how you feel about using Appimages.
The reason for using the Emacs Appimage was the version in the repos doesn't support elpher.
https://kristall.random-projects.net/
https://appimage.github.io/Emacs/
ruenoak.
#12 2021-02-13 02:26:10
dice
Re: Gemini protocol
Try
Thanks, that fixed it.
Edit: just want to say gmni / gmnlm is really cool bit of software.
#13 2021-02-13 04:21:34
andyprough
Re: Gemini protocol
ruenoak.
Sounds good, thanks ruenoak. If this Lagrange browser I'm trying gives me any grief I'll try Kristall next. So far it's doing real well though and seems to be well maintained.
#14 2021-02-13 05:04:38
ruenoak
Re: Gemini protocol
@andyprough Not a problem, I'm going to try out Lagrange too, always interested in trying new browsers.
ruenoak
#15 2021-02-13 15:40:02
Ogis1975
Re: Gemini protocol
I use Amfora https://github.com/makeworld-the-better-one/amfora  Amfora aims to be the best looking Gemini client with the most features... all in the terminal.
Here screen:
Also, you can check the simplest one- the AV-98 client. It's written in Python and runs in a terminal. AV-98 has no "strict dependencies", i.e. it will run and work without anything else beyond the Python standard library.
Here link https://tildegit.org/solderpunk/AV-98
And here screen:
            ----+- Peter Kropotkin -+----
#16 2021-02-14 00:24:39
yeti
Re: Gemini protocol
makeworld-the-better-one / amfora wrote:
Amfora aims to be the best looking Gemini client with the most features... all in the terminal. It does not support Gopher or other non-Web protocols - check out Bombadillo for that.
Sometimes members of the geminiverse look like focussing at being divisive.  Not even Gopher support?  Come on!  We need browsers that unite, especially because there is a lot of cross linking between the Gopher and Gemini dimensions!
And for the occasional link from a gopher hole to some unavoidable pages via HTTP, some of the well known TUI browsers are neat (elinks, emacs, links, lynx).  Some of them additionally can access news, mail, fsp, and lots of other protocols too.
THAT IS WHAT A BROWSER WAS MEANT TO BE IN THE BEGINNING OF THE WEB!
Please unite instead of being divisive.
#17 2021-02-14 10:02:25
ruenoak
Re: Gemini protocol
I haven't tried Amfora but I am quite liking the simplicity of AV-98
#18 2021-02-21 13:13:32
dice
Re: Gemini protocol
I use fdroid app repo on my phone and found a cross platform Gemini browser called deedum if anyone is interested in that sort of thing.
It seems to work really well.
https://github.com/snoe/deedum
#19 2021-02-21 13:36:31
yeti
Re: Gemini protocol
Cross protocol browsers are more fun!
#20 2021-02-22 04:32:44
ruenoak
Re: Gemini protocol
Looks interesting, always good to see whats out there. I'm using Ariane by OppenLab https://oppen.digital/ on android, looks like you can get it for fdroid too. Not cross platform though.
@yeti yes cross protocol browsers would be nice, even in the form of an addon
#21 2021-02-22 13:35:17
dice
Re: Gemini protocol
Wouldn't they, but how would E Corp make their mega bux!
#22 2021-02-22 13:39:24
dice
Re: Gemini protocol
Ariane seems a bit more user friendly than deedum, thanks.
By not cross platform i suppose this is not compatible on iphone and some other non android devices?
#23 2021-03-31 13:16:40
Danielsan
Re: Gemini protocol
I love it!
I use Lagrange through Flatpak!
#24 2021-04-15 01:07:44
ruenoak
Re: Gemini protocol
Danielsan wrote:
I love it!
Yes I was using the Lagrange Flatpak too.
I'm trying out Amfora at the moment
#25 2021-04-15 01:50:42
andyprough
Re: Gemini protocol
Distrotube has made his main website a capsule on Gemini - gemini://distro.tube
