#1 2021-01-31 22:49:17
vazhnov
[SOLVED] Docker images
Hi all!
I created another one public repository with Devuan docker images and a small documentation: https://hub.docker.com/r/vazhnov/devuan
Images are tiny, about 30 MB compressed.
Also I see another unofficial Devuan images repositories: https://hub.docker.com/search?q=devuan&type=image
Any ideas how to create official one?
#2 2021-02-09 20:59:30
climbingturtle
Re: [SOLVED] Docker images
Cool!
I haven't yet got around to play so much with docker, but it's beeing used more and more for labs and such at the company I work for. So it feels very good to know that I can, with your work, use Devuan with docker whenever I'll come around to it!
#3 2022-12-25 23:59:39
vazhnov
Because there is no possibility to automate images creation in hub.docker.com with free account, I decided to learn GitLab pipelines and created this: https://gitlab.com/vazhnov/devuan-docker-images.
Images to be created automatically: Devuan 4 Chimaera — every month, Devuan 5 Daedalus — every week. The schedule is here: https://gitlab.com/vazhnov/devuan-docke … _schedules.
Container images registry: https://gitlab.com/vazhnov/devuan-docke … r_registry.
The code is still not perfect, I'm working on it.
It would be great to have an access to another GitLab instance without strict limits.
#4 2022-12-26 00:55:04
Are you aware that there are now Devuan container images on the Docker Hub? They
can be found at https://hub.docker.com/u/devuan
Announcement was here
