#1 2021-01-28 19:51:23
graphite
How do I install backports in Beowulf?
Hello,
I want a newest packages possible.
#2 2021-01-28 20:09:53
Re: How do I install backports in Beowulf?
That's not how backports should be used.  If you upgrade everything in backports it could fubar your system.  Only use backports for specific packages that are needed.  For example, if you get a new video card and need newer firmware.
If you want the very newest run ceres (unstable) but be prepared for breakages.
#3 2021-01-28 20:11:09
graphite
Thank you. How do I install backports of specific packages?
#4 2021-01-28 20:48:28
Read https://www.devuan.org/os/packages.
apt -t beowulf-backports install package
#5 2021-01-28 21:26:01
graphite
Thank you very much! smile
I added:
deb     http://deb.devuan.org/merged beowulf-backports main
deb-src http://deb.devuan.org/merged beowulf-backports main
to sources.list, and then 'sudo apt update'.
