#1 2020-12-22 21:10:15
rgl808
Info » AppImage security and alternatives
Some ".AppImage" applications come from untrustworthy publishers. You can use "bwrap/firejial" to restrict the running environment of those ".AppImage" applications.
If you have a better way to restrict the running environment of ".AppImage" applications, please reply.
[Info] (Please,dont reply/quote this, a reply/quote to this may can cause a nonsense discussion and a permanent loss of neurons)
Review "X" if you want, but be shure to share your best idea if you have ideas to solve/improve "X".
Are you going to criticize "X"?:
-Stop if you can (you may not know what you are talking about, no one knows everything)
-Explain why and wait for someone that have ideas to solve/improve "X" (if you think you may know what you are talking about)
#2 2020-12-22 21:45:13
Re: Info » AppImage security and alternatives
Or better yet, just don't use "appimage" at all.  I suspect that there aren't many devuan users who would touch it.
#3 2020-12-22 22:29:18
^ This.
See also https://www.techrepublic.com/article/wh … -on-linux/ & http://kmkeen.com/maintainers-matter/
#4 2020-12-23 11:14:00
rgl808
Thank you for reply.
#5 2020-12-23 12:00:28
rgl808
My way to go:
1: apps from official distribution repositories
2: tar ball + binaries
3: apps from source
4: flatpak apps [try to avoid/dont promote]
#6 2020-12-23 12:40:29
dice
Can these appimages be used in software centers like gnome software or kde etc? Ive never used them, just curious how they are got.
#7 2020-12-23 14:24:43
rgl808
#8 2020-12-23 14:52:35
These pre-packaged all-in-one apps are an aberration and insult to Linux users.  Methinks they are for handicapped Winblows refugees who don't know what they're doing.
#9 2020-12-23 15:16:43
dice
looks as though they are trying to emulate google play store, apple itunes, microsoft download etc for the gnome smartphone software, ever increasingly gnome desktop will probably morph into an android/iphone os spinoff. I was looking at that gnome look org and some of the top themes are all apple mac clones for gtk3, lol...
#10 2020-12-23 15:58:21
rgl808
#11 2020-12-23 16:44:10
rgl808
Analytics in each site: "Flatpak", "AppImage", "Snapcraft".
Flatpak:
AppImage:
Snapcraft:
#12 2020-12-23 16:51:40
rgl808
https://thp.io/2019/flatpak-vs-snapcraft.html
Distribution Packages
I still hope that there's a place for distribution packages. The leaf packages ("apps") do need some kind of sandboxing, as sandboxing is good and important to have (not only to protect the "root" user, but protect the user's data, as usually there's more privacy-related juicy info in $HOME than in all of the system folders).
Even with Flatpak, there's still some duplication (e.g. the GTK version from the distro package and the Freedesktop Platform Flatpak), but it's better than Snap's "let every snap ship with its own version of ICU" or AppImage's "just run this executable, it contains Everything" approach.
#13 2020-12-23 18:37:52
rgl808
After these replies i learned (hope this help someone):
"AppImages", "Flatpak" projects are good for portability
BUT
if we promote these projects may one day new linux users will left behind the distribution repositories replaced by one centralized platform like the "Apple""App Store"/"Google""Play Store".
#14 2021-01-03 08:54:29
ToxicExMachina
Anyone who recommend flatpak should note that flatpak is a big security hole itself by design. Flatpak is also SystemD-exclusive package manager. Snap is the same thing as flatpak. As for Appimage it's important to understand that Appimage is just an auxiliary way of software distribution. Consider Appimage as an advanced tarball. Of course, tarball is simpler and way more open thing than Appimage.
There is a problem: corporations are trying to force way of thinking incompatible with sane technical solutions.
#15 2021-01-03 09:36:41
Nope: https://pkgs.alpinelinux.org/packages?n … ranch=edge
And it's spelled "systemd" FFS... mad
#16 2021-01-03 11:36:37
dice
why does this trigger you so?
When people spell it that way it always makes me think of that manga/anime cartoon initial D
#17 2021-01-03 12:38:21
I don't get that either, let's just refer to systemd or system-d as system dumb from now on. Since it is so buggy and crappy...
wink
#18 2021-01-04 20:56:42
mweishaar
I've used two appimages.
1. Kdenlive.  They implemented some new features in the latest version (20.12), and I am on 18.12.3 w/beowulf.  KDE provided the appimage.  I don't use it all that often, but the new features are nice.
2. I have a live-usb-maker appimage from the MX-linux team.  For some reason, I couldn't get a bootable USB to work (i.e. boot) using unetbootin.
I don't mind them at all, but I wouldn't want to use them exclusively.
#19 2021-01-17 04:18:38
I have touched appimages in the past and occasionally still do, but that being said, you are probably right about appimage.
They probably aren't as secure or trustworthy as official repos for distros you trust.
I should add, i don't  flatpak and especially snaps even more so.
I am not sure about guix package manager, or other alternatives... but snap and npm ones currently rank my least trusted methods of installing.
Especially now that I know about ubuntu's non-free server for snaps. hmm
Aka, walled garden anyone?
#20 2022-06-07 13:56:04
SpongeBOB
Hi everyone,
Real interesting topic !
I'm trying to install ATOM (off-line) https://dev1galaxy.org/viewtopic.php?pid=36174#p36174 with the most practical solution possible.
I've been recommended to use appimage with Firejail. What you think about that solution ?
