#1 2020-12-02 13:11:46
dnss
Does apt switch to mirrors automatically when performing an upgrade?
I'm using Beowulf with the regular Devuan.org repos.
I did apt upgrade yesterday and noticed that it was downloading the updates from somewhere other than devuan.org.
It went by pretty quickly so I didn't notice the full message, but I'm pretty sure it said it was retrieving the updates from a domain other than devuan. I can't remember the domain name, I thought it said "fast" in there somewhere, but like I said it went by pretty quickly.
I did poke around in the logs, but couldn't find where the updates came from.
I'm probably being a little paranoid, but I just wanted to make sure that it's normal for a devuan installation to switch to a mirror when upgrading. Hopefully I'm not being completely daft here.
#2 2020-12-02 13:38:27
dice
Re: Does apt switch to mirrors automatically when performing an upgrade?
Ive noticed this mirror recently when installing some software, was a few days ago, cant remember what it was exactly.
ftp://devuan.ipacct.com/devuan-cd/
Im not sure how the mirrors work in devuan when you choose local mirror setup but i think it safe to say it pulls in network mirrors that are closest to you geographically.
The mirror you may be thinking of could be in the below link.
https://www.devuan.org/get-devuan
#3 2020-12-02 14:49:27
Devuan has a round-robin of package mirrors:
http://pkgmaster.devuan.org/mirror_list.txt
iso mirrors and package repository mirrors are two different things.  wink
#4 2020-12-02 15:24:42
dice
iso mirrors and repository mirrors are two different things.  wink
I thought that when i posted my reply, but was hinting at the actual repo mirror being
Which is feckin fast for my neck of the woods, was getting 4 mb per second on that mirror.
#5 2020-12-02 16:09:57
They do know how to dance in Bulgaria!!
Some iso mirror providers also host a package mirror but not all.  And some package mirrors may not provide iso mirrors.  To lazy to diff the two lists.
#6 2020-12-02 22:13:46
The only time I have trouble connecting to the/a mirror is when the repos are being updated, just recently like for kernel 5.9 :-), But I check nearly everyday and notice sometimes for a few days at most the repo is unreachable. When this happens I switch to the main one and not the local mirror for a while.
