#1 2020-11-27 09:26:50
dice
Banned packages
im wanting to see the list of banned packages but it downloads as an empty .txt file ??? Maybe bad link?
https://www.devuan.org/os/explore
https://pkgmaster.devuan.org/bannedpackages.txt
EDIT: dont know why but geany didnt like the .txt file and wouldnt open it but nano was ok with it. Must be formatted differently?
#2 2020-11-27 11:07:49
xinomilo
Unknown
Re: Banned packages
same with pluma (encoding issues). nano shows some weird line 1 :
^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@unstable,systemd-timesyncd
if you remove this line, it works as expected with any editor. note that "unstable,systemd-timesyncd" in line 1 is also present in last line.
#3 2020-11-27 12:33:25
dice
Re: Banned packages
file is saying application binary file ?
~/Downloads $ > file -i bannedpackages.txt
bannedpackages.txt: application/octet-stream; charset=binary
#4 2020-11-27 17:27:14
Re: Banned packages
This may be due to some backend changes in the pkginfo function which is still somewhat of a WIP.
#5 2020-11-28 05:42:20
dice
Re: Banned packages
gotcha, used to be just a web page back a little while ago when i first looked into devuan.
