#1 2020-11-17 10:16:57
Dutch_Master
Forum frequently missing
Recently I've been unable to connect to the forum on various occasions. It seems to fix itself over time, so perhaps it's a load issue (too many connections?) Page loading is also longer then normal, although that too is variable. Makes me suspect a DDOS attack?
FYI: other sites respond normally, loading times are also as expected from those, so I'm pretty sure it's not my ~100Mbit/s connection.
#2 2020-11-17 11:54:49
PedroReina
Re: Forum frequently missing
Same behaviour here.
#3 2020-11-17 16:04:21
Suspect the sys admin working on Devuan's infra.  I think I remember that notes to that effect were posted on irc but not on the forum.
#4 2020-11-17 18:35:35
Dutch_Master
That would make sense and is much preferable to a DDOS attack wink
Alas, I'm not on IRC so didn't see that. Hopefully the team will remember to post a warning on the forum too on the next instance.
Thx!
