#1 2020-11-06 22:56:01
nobodyuknow
SOLVED: KDE: Delete icons from panel and transparent Audio Volume icon
I just built a KDE system mainly to learn the vagaries of that desktop.
I added a number of icons to the panel, including Konqueror. However, I'm not impressed with Konqueror, as it displays an Undocumented Error upon starting, something to do with the home page, I guess. So I thought I'd delete the icon from the panel. But unlike with Cinnamon or MATE, right-clicking on the icon does not provide a menu option to remove it. Dragging it does not work either. How are icons deleted from the panel?
I actually read the release notes, so I was able to get sound to work. But when I placed Volume Control on the panel, the icon was transparent. I know it's there because I can click on it and get it to display. Any hints on how to make it visible?
#2 2020-11-07 08:37:12
PedroReina
Re: SOLVED: KDE: Delete icons from panel and transparent Audio Volume icon
May be your widgets are locked. Try this:
On the panel, click secundary mouse button, Unlock widgets.
#3 2020-11-09 21:53:23
nobodyuknow
@PedroReina
Thanks for the reply. No, that wasn't it. Eventually I discovered that Panel Options -> Configure Panel offered a way to remove any of the icons.
As for the transparency, it's a feature of the icon set I chose, GNOME. Most of the icon sets include a transparent Audio Volume. Breeze and Breeze Dark are the only ones (of the default sets) that include a visible one. I would think it's a bug.
#4 2020-11-09 22:14:23
Gnome is a bug.
#5 2020-11-11 20:31:27
nobodyuknow
@golinux
I agree, but I like its icons.
