#1 2020-10-18 20:50:32
PengouinPdt
[Ceres] Xfce4: not more xfce4-panel | kernel 5.9
Hi.
Today, I updated my Ceres. I use Xfce4 as WM.
But after my reboot, I do not have xfc4-panel.
I test to use this command:
# xfce4-panel --replace
without success.
When I use:
# xfce4-panel --restart
A error message window appears, and inform that:
(message is in French)
Impossible de redémarrer le tableau de bord.
GDBus.Error:org.freedesktop.DBus.Error.ServiceUnkonwn:
The name org.xfce.Panel was not provided by any .service files
# xfwm4 --replace
not change anymore.
Just FYI:
uname: 5.9.0-1-amd64 #1 SMP Debian 5.9.1-1 (2020-10-17) x86_64 GNU/Linux
Oh, with the previous kernel 5.8.0-3-amd64 #1 SMP Debian 5.8.14-1 (2020-10-10) x86_64 GNU/Linux, Xfce4 runs correctly!
Any idea to resolve?
#2 2020-10-18 21:35:39
Re: [Ceres] Xfce4: not more xfce4-panel | kernel 5.9
I have heard that the new kernel is really messed up.  And dbus is  . . . well . . .
#3 2020-10-19 08:52:14
xinomilo
Unknown
also seen other (=alsa) errors in booting with new 5.9 kernel.. stick to 5.8 from testing/chimaera, and maybe file/search a bug report in debian about it..
#4 2020-10-19 17:43:39
Sounds like it's expecting a systemd unit file to be running. But this could just be a ceres SNAFU, waiting a bit then updating again can fix things sometimes.
#5 2020-10-20 11:41:24
PengouinPdt
@Head_on_a_Stick: yes, I believe, too.
Thanks @ll
#6 2020-10-20 17:03:51
manyroads
I, also, found 5.9 to cause hard failures (mine were largely with VirtualBox). It's fixable with a rollback to 5.7.
Pax vobiscum,
Mark Rabideau - ManyRoads
dwm, i3wm, openbox on debian test ~ Linux #449130
#7 2020-10-25 08:25:10
PengouinPdt
Thanks. I rollback on the previous 5.8.x wink
#8 2020-10-28 06:47:05
Danielsan
Kernel 5.9 also doesn't work with NVIDIA blobs...
#9 2020-12-18 04:46:44
czeekaj
I am on 5.9 on this laptop.
I have not noticed any issue with Xfce4-panel (4.12 version)
I am using openbox session. w/ Ati gpu.
#10 2020-12-18 07:41:14
Hi, I'm using linux-image 5.9 kernel and the nvidia proprietary driver is installed as well.
I use modeset.nouveau=0 on the grub2 command line (/etc/default/grub)
 GRUB_CMDLINE_LINUX_DEFAULT="nokmsboot nouveau.modeset=0 console=tty12 vga=794"
inxi gives...
Fri 18 Dec 17:30:31 AEST 2020
root@GamesBox:~# inxi -G
Graphics:  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 455.38
           Display: server: X.org 1.20.4 driver: nvidia tty: 115x36
           Message: Advanced graphics data unavailable in console for root.
root@GamesBox:~# logout
glenn@GamesBox ~ $ inxi -G
           Display: x11 server: X.Org 1.20.4 driver: nvidia resolution: 1920x1080~60Hz
           OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 455.38
hope this helps
[edit] Beowulf 3.0 ;-)
