#1 2020-10-10 20:42:46
sadegh
Can not extract baleno etcher
I just downloaded baleno etcher, but can not extract it , on my desktop - 64 - .
#2 2020-10-10 20:55:58
Re: Can not extract baleno etcher
Please share the exact URL from which you downloaded and also post exactly how you are trying to extract it.
The AppImage is a .zip file so use unzip on it. There are also .deb files available.
It may be worth noting that almost all ISO images can be transferred to a USB stick with the plain cp command.
#3 2020-10-10 21:07:50
sadegh
/home/sadegh/Documenten/Schermafdruk_2020-10-10_23-04-51.png
/home/sadegh/Documenten/Schermafdruk_2020-10-10_23-05-31.png
As you see, I can not use synaptic package manager.
#4 2020-10-10 21:12:17
sadegh
/home/sadegh/Documenten/Schermafdruk_2020-10-10_23-11-16.png
And... I can not use terminal
#5 2020-10-10 21:14:47
I can't see anything but in respect of Synaptic perhaps see https://dev1galaxy.org/viewtopic.php?id=3862
#stabinthedark
Please post the terminal output here directly (using code tags).
#6 2020-10-10 21:27:50
sadegh
sadegh@dhcp-077-251-207-089:~$ sudo apt-get update
[sudo] wachtwoord voor sadegh:
sadegh zit niet in het sudoersbestand.  Dit incident zal worden gerapporteerd.
#7 2020-10-10 21:42:38
FM81
Devuan behaves more like a real linux; may be it is better to use
su
and get a real root-shell instead continuing the biggest mismatch from last years. (I mean setting 'sudo' in front of every command.) The default-password for root should be 'toor' ...
Greetings, FM_81
The most brilliant role in comedy is that of a fool, he must not be in order to make it seem. (Miguel de Cervantes)
#8 2020-10-10 21:43:58
sadegh
And this one about synaptic. when i put the usb stick of devuan 3 in, it don't take it.
/home/sadegh/Documenten/Schermafdruk_2020-10-10_23-41-40.png
#9 2020-10-10 21:45:18
sadegh
sadegh@dhcp-077-251-207-089:~$ su apt-get update
su: user apt-get does not exist
#10 2020-10-10 21:46:46
sadegh
sadegh@dhcp-077-251-207-089:~$ apt-get update
Pakketlijsten worden ingelezen... Klaar
E: Kon het vergrendelingsbestand /var/lib/apt/lists/lock niet openen - open (13: Toegang geweigerd)
E: Kan de map /var/lib/apt/lists/ niet vergrendelen
W: Probleem bij het ontkoppelen van het bestand /var/cache/apt/pkgcache.bin - RemoveCaches (13: Toegang geweigerd)
W: Probleem bij het ontkoppelen van het bestand /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Toegang geweigerd)
#11 2020-10-10 21:55:45
@sadegh . . . we cannot see any images on you computer.  Please post online somewhere.
#12 2020-10-10 21:56:04
FM81
Type su and ENTER.
You will be asked for the root-password. Type toor and ENTER again. (No screen-output here.)
Now you are 'root' and there is no need to put anything in front. You can test "who you are" by
whoami
#13 2020-10-10 22:12:28
sadegh
i did and than i see my own name
#14 2020-10-10 22:24:33
In Beowulf try su -
#15 2020-10-10 22:29:57
sadegh
Nothing changes
#16 2020-10-11 08:41:36
There is no "default" root password in an installed system. The OP should enter the root password that they supplied during the installation.
You really shouldn't use commands if you don't understand exactly what they will do. Read man su before using it.
tl;dr:
su -c 'apt-get update'
And please upload your screenshots to an image hosting site and share the link here, we can't help you otherwise.
#17 2020-10-11 09:13:01
FM81
Of course you are correct! My fault, I was in thoughts about a devuan-raspberry-image during writing this (which isn't the case here). Sorry ...
Greetings, FM_81
