#1 2020-09-11 20:40:39
F_Sauce
Strange behaviour using network commands: ifconfig, ifup, showmount...
Hello.
Don't know if this has been discussed before, but after upgrading to Beowulf I found I had to be in the directory of /sbin to execute some network related configuration programs located there; I guessed, correctly, that /sbin wasn't in the path, however, the ip command does work which puzzled me a bit.
Any thoughts on this?
Cheers,
Olav
I'm on Devuan with KDE
#2 2020-09-11 21:11:44
Re: Strange behaviour using network commands: ifconfig, ifup, showmount...
Have you read the Release Notes?
#3 2020-09-12 00:37:00
F_Sauce
Thank you, I hadn't.
