#1 2020-06-30 21:34:42
roluan17
[SOLVED]Detached signature file(s)
Hi
since upgrading from ascii to beowulf, I get the following errors, when I do:
apt-get update:
Detached signature file '/var/lib/apt/lists/partial/us.deb.devuan.org_merged_dists_beowulf_Release.gpg' is in unsupported binary format
for each of these sources:
us.deb.devuan.org_merged_dists_beowulf-security_Release.gpg'
us.deb.devuan.org_merged_dists_beowulf-updates_Release.gpg'
apt-get install devuan-keyring
is answered by:
devuan-keyring ist schon die neueste Version (2017.10.03).
(keyring is already newest version)
Anyone can help?
#2 2020-06-30 22:38:30
Re: [SOLVED]Detached signature file(s)
From the Devuan website:
Devuan has a network of package repository mirrors in place. The mirror network is accessible using the FQDN “deb.devuan.org” via http NOT https. Country Codes (CC) are currently unavailable but a specific mirror from the list can be accessed using the corresponding BaseURL.
Instructions for getting the keyring can also be found on the website at: https://devuan.org/os/keyring
#3 2020-07-01 06:08:19
roluan17
Thank you!
Keyring was the newest.
All seems to be fine now, replaced country mirrors.
greetings
