#1 2020-06-24 01:42:21
NickWilliamsPoetArtist
Musescore
just updated from ascii to beowulf everything worked ok apart from musescore which for some reason has lost its playback function and sound doesn't work on it due to this (changing the soundfont makes no difference so I uninstalled and installed musescore from jessie and that worked ok ... however was unable to install musescore from ascii which worked perfectly (there is a work around as I can still export the scores to midi and mp3 etc to listen but just not listen whilst I am writing
qtbase-abi-5-7-1 is what is required for ascii musescore to be reinstalled but the updated libqt5core5a file can't be removed without removing a whole bunch of other packages which I use
just wondering if there is a work around or if downloading musescore src deb and attempting to compile for my system is the only option to get the playback function back ?
All the best
Hope everyone is coping with current covid situation
#2 2020-06-24 01:46:15
Re: Musescore
Perhaps this would help?
#3 2020-06-24 06:57:08
larsH
Re: Musescore
Hi
Go into settings and change the I/o backend to alsa. This is better than using pulseaudio. In the case with musescore I get scratching playback using PulseAudio. Alsa works perfect (and is the default for Devuan). I am using musescore myself quite a lot as a musician.
I would also suggest you to install musescore3 from backports. It is more modern and just as stable as the old version.
Have a nice day
Lars H
#4 2020-06-24 16:30:30
GNUser
Re: Musescore
AppImage is also available. Sometimes issues in .deb version do not affect AppImage version:
https://musescore.org/en/download
#5 2020-06-25 15:08:47
Re: Musescore
Thankyou (changing to alsa fixed problem) will look into other as it might have an insight into the only other issue I found which was firefox when firejailed no longer plays sound and I had noticed something in the firejail firefox-common profile that said that pulseaudio might be broken
Cheers
All the best
Nick
#6 2020-06-25 15:22:30
Re: Musescore
Cheers for the pulseaudio conf info that fixed firefox firejail prob too so all good (am using sysvinit anyway but figured the upgrade may have overwritten the conf file)
All the best
Nick
