#1 2020-06-04 14:16:31
criminalscum
Why apt still links to libsystemd0?
Hi.
So i wanted to look into apt source code to see why it links to libsystemd0 at runtime instead of having an option to detect systemd presence at compile time. I mean, it should't matter if it's detected at runtime or compile time, if systemd absence is detected at runtime, then it can't use it anyway, right? So when we're compiling apt we should be able to tell it beforehand that systemd isn't going to be there. This "runtime detection" of systemd to me seemed sketchy anyway.
To my surprise i've found define called `HAVE_SYSTEMD` already present in source code and since i don't have systemd installed on my system, after i compiled apt from source, apt-get doesn't link to libsystemd0 anymore.
I'm just asking, i'm not pushing anyone to make any changes, i just want to know why is it so, okay? From what i'm seeing in Git log, this define was added in 2019.
Does it link to libsystemd0 because apt in Devuan is build from older source code or is that because apt in Devuan is built on Debian that has systemd? Any plans to rebuild it w/o libsystemd0? This file seems to be installed by libelogind0 and i can't remove libelogind0 without removing apt.
I mean, i probably can rebuild it from source and install instead of upstream apt, and i probably should do that at some point, but replacing apt with custom build doesn't sound as a safe option to me, so i wanted to ask first.
Any ideas?
#2 2020-06-04 14:57:22
HevyDevy
Re: Why apt still links to libsystemd0?
Hmm that is odd, i dont have libsystemd0 on my system but do have libelogind0.
:~$ apt depends libelogind0
libelogind0
  Depends: libc6 (>= 2.28)
  Depends: libcap2 (>= 1:2.10)
  Conflicts: libsystemd0
  Replaces: libsystemd0
    libelogind0
I run a pretty slimmed down system though, it has dbus and systemd disabled ( i believe) via apt preferences.
/etc/apt/preferences.d/nodbus
Package: dbus
Pin: release n=beowulf-security
Pin-Priority: -1
Package: dbus
Pin-Priority: -1
/etc/apt/preferences.d/nosystemd
Package: systemd
Pin-Priority: -1
#3 2020-06-04 15:10:48
criminalscum
It's installed by libelogind0.
$ ldd $(which apt) | grep -i systemd
$ dpkg -S /usr/lib/x86_64-linux-gnu/libsystemd.so.0
#4 2020-06-04 15:15:07
HevyDevy
I see, i didnt have the correct commands for apt.
I dont think there is any way of getting around this as devuan is a fork of debian. I believe it would require a rewrite of the code and a massive downgrade of binaries in the repos.
This is why i like to play around with pure unix like openbsd and netbsd.
#5 2020-06-04 15:31:50
anticapitalista
Isn't it a symbolic link to libelogind.so.0?
#6 2020-06-04 15:38:21
criminalscum
No, it appears to be just a matter of recompiling apt with `HAVE_SYSTEMD` unset. It is unset when systemd isn't present. I have compiled apt from source code on Devuan (Beowulf) and apt doesn't link to libsystemd0 anymore.
You can try it yourself, source code is here: https://github.com/Debian/apt
You will need `triehash` somewhere in your path, utility itself is here: https://github.com/julian-klode/triehash, then `ln -sf /path/triehash.pl /otherpath/bin/triehash` and `/otherpath/bin` has to be in $PATH so cmake can see it when configuring apt build. The rest of the packages needed for build can be installed from Devuan repos.
#7 2020-06-04 15:41:24
This problem is fixed in Chimaera and will be also in the Beowulf point release (coming soon) iirc
#8 2020-06-04 16:04:12
criminalscum
Nice. Thank you.
#9 2020-06-04 22:14:15
pcalvert
Yes, you are correct.
Phil
Another one is called Luxxle.
#10 2020-06-04 22:24:22
pcalvert
That's not a problem. It's essentially a "fake" systemd component -- libelogind0 put that there because some software expects libsystemd0 to be present. The software "thinks" it's "talking" to libsystemd0, but it's really "talking" to libelogind0.
Phil
#11 2020-06-04 22:42:33
bgstack15
I am concerned that apt has been modified to use systemd. Would anyone well-versed in the subject try to explain it to me? I will also at some point to try to look at the source, but if anybody could summarize, that would help everyone else out!
#12 2020-06-04 23:07:41
pcalvert
The apt package in Devuan comes directly from Debian; it is an unmodified Debian package.
Phil
#13 2020-06-05 00:13:38
sgage
Apt has not been modified to use systemd. I have no trace of sysemd on my computer (running beowulf), not even libsystemd0, and apt works just fine. I really don't know what else to say.
#14 2020-06-05 09:50:33
Not sure about "well versed" but I can tell you that the apt binary is linked to /lib/x86_64-linux-gnu/libsystemd.so.0 during compilation — this is because GNU/Linux uses dynamic linking.
In Devuan's case /lib/x86_64-linux-gnu/libsystemd.so.0 is symlinked to /usr/lib/x86_64-linux-gnu/libelogind.so.0 so at no point is systemd invoked in any way.
EDIT: better link.
#15 2020-06-05 12:17:52
bgstack15
@Head_on_a_Stick, thank you! I know the term dynamic linking, but that page has more information than I'll be able to absorb for a long, long time! But specifically, would you know any of the motivations of the apt maintainers who made the choice to link apt to libsystemd0?
#16 2020-06-05 16:37:29
No but I would hazard a guess that it is related to the systemd timers now supplied with the package (or perhaps the new sandboxing feature).
#17 2020-06-05 17:17:46
criminalscum
They are attempting (not necessarily successfully) to prevent shutdowns/reboots while package manager is running, but that code depends on systemd-logind (or maybe elogind) and doesn't work if, for example, dbus isn't running or something else went wrong. Also i don't know how elogind is going to prevent shutdown/reboot if init system isn't systemd.
The code is here: https://github.com/Debian/apt/blob/cb60 … l.cc#L3444
Another thing they do with systemd is that they track if package manager was invoked in interactive mode/shell or not and include that info into HTTP requests to repo servers. That code is also completely depends on systemd and won't work if you are not running systemd.
https://github.com/Debian/apt/blob/cb60 … tp.cc#L981
Besides that i didn't find any more systemd call in apt.
#18 2020-06-05 17:21:28
larsH
Hi
Devuan is based on Debian. The goal of Devuan is to be free of systemd in order to let people decide which init system to use. That is why libsystemd0 is an empty package. The other goal is to keep things simple (it means not to maintain to many packages). It is in the mind of the developers of apt (which of course is from debian and ubuntu) that the decisions of what apt should depend upon is taking place. I am sure you can find more information on debians apt-devel mailing list. It will be a lot of work with no practical benefit to remove the empty systemd0 package. If it easy to do without removing a lot of packages I am sure it was already done.
I hope this answer was helpfull
Have a nice day
Lars H
#19 2020-06-05 18:11:16
Ah, interesting. Thanks!
It probably won't. AFAIUI the developers have made the decision to stub out most of the (unwanted) extra functionality offered by systemd.
