#1 2020-03-06 17:58:34
nobodyuknow
SOLVED: Brisk menu (mate-applet-brisk-menu) is not available
For MATE, the Brisk menu from Ubuntu MATE is the best, in my opinion. It is not available via Synaptic. I could obtain the Ubuntu deb-file from
and then perhaps (!) install mate-applet-brisk-menu_0.6.0-1_amd64.deb, but that might cause trouble when Devuan adds it the official way. Is Brisk menu going to be added to Devuan packages any time soon?
#2 2020-03-07 09:45:19
xinomilo
Unknown
Re: SOLVED: Brisk menu (mate-applet-brisk-menu) is not available
mate-applet-brisk-menu is in devuan, ascii-backports & beowulf. : https://pkginfo.devuan.org/cgi-bin/d1pk … elease=any
#3 2020-03-07 18:38:43
nobodyuknow
Maybe it's an upgrade problem. I built a 2.0 system (because 2.1 does not offer my wireless drivers) and executed the following commands in a terminal
sudo apt clean
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
but there were no upgrades to be had. Synaptic does not offer mate-applet-brisk-menu and "sudo apt install mate-applet-brisk-menu" is equally unsuccessful. Is there a better way to upgrade?
#4 2020-03-07 19:16:12
You have to enable ascii-backports in your sources.list.
#5 2020-03-07 20:26:51
nobodyuknow
Sorry, I misunderstood that.
I edited sources.list to the following:
deb http://deb.devuan.org/merged ascii main non-free contrib
deb-src http://deb.devuan.org/merged ascii main non-free contrib
deb http://deb.devuan.org/merged ascii-security main non-free contrib
deb-src http://deb.devuan.org/merged ascii-security main non-free contrib
deb http://deb.devuan.org/merged ascii-updates main non-free contrib
deb-src http://deb.devuan.org/merged ascii-updates main non-free contrib
deb http://deb.devuan.org/merged ascii-backports main non-free contrib
deb-src http://deb.devuan.org/merged ascii-backports main non-free contrib
However, nothing changed. Did I get sources.list wrong?
#6 2020-03-07 21:37:53
Did you update sources after editing?
#7 2020-03-08 09:45:01
That package does not come automatically. As root enter:
apt update
apt -t ascii-backports install mate-applet-brisk-menu
It may be worth to read: https://wiki.debian.org/Backports
#8 2020-03-08 22:25:41
nobodyuknow
Thanks for the assistance.
@golinux I assumed that sources.list would be read by Synaptic. I was wrong.
@rolfie So that's the way to specify a repository when installing. And backports makes sense now in the context of packages existing in testing, but not stable.
#9 2020-03-09 01:09:24
You will want to update synaptic every time you want to browse or install etc. so it can find the newest packages.   You also need to do that in a terminal.
The -t is only needed because backports has some kind of magic pinning so everything from there doesn't get installed.  I comment backports in my sources list and only uncomment when I want to install something specific.
#10 2020-03-09 12:17:53
xinomilo
Unknown
just for reference :
"Reload" button in synaptic, does the same thing (`apt update`). so, whenever you open synaptic, it's best to do that first.
synaptic menu also has an option to pick version : mark package, then 'Package' -> 'force version'. (same as `apt install -t release package`)
#11 2020-03-09 23:56:12
nobodyuknow
I tend to use terminal apt commands when I know the name of the package and Synaptic when I'm guessing. I'm embarrassed that I never noticed the Reload button.
