#1 2020-02-16 22:00:20
nobodyuknow
SOLVED: Temporary failure resolving http://us.deb.devuan.org
I installed Devuan from netinst. I chose no desktop because I want to create a Budgie system with no other desktops. The new system booted into console. Unfortunately I do not have access to Ethernet, so I am forced to configure wireless. I looged into root and executed the following commands:
/sbin/ifconfig wlan0 up
/sbin/iwconfig wlan0 essid SSIDatthelibrary
/sbin/dhclient wlan0
The last command took much longer (minutes) than I expected, but eventually it completed. Then I tried:
apt update
but a message kept repeating:
Did I miss a step or is http://us.deb.devuan.org taking a holiday today? I'm posting this from another Devuan system (same laptop, but a different SSD in an external enclosure) at the same library, so wireless is working at least somewhat well.
P.S.
/etc/apt/sources.list is as follows:
# deb cdrom:[devuan_ascii_2.0.0_amd64_dvd-1]/ ascii main non-free
deb http://us.deb.devuan.org/merged ascii main non-free contrib
deb-src http://us.deb.devuan.org/merged ascii main non-free contrib
deb http://us.deb.devuan.org/merged ascii-security main non-free contrib
deb-src http://us.deb.devuan.org/merged ascii-security main non-free contrib
deb http://us.deb.devuan.org/merged ascii-updates main non-free contrib
deb-src http://us.deb.devuan.org/merged ascii-updates main non-free contrib
#2 2020-02-16 23:17:11
Re: SOLVED: Temporary failure resolving http://us.deb.devuan.org
There is no US mirror and County Codes (CC) are currently deprecated in Devuan.  Use the round-robin pool of repositories at “deb.devuan.org” via http not https.  The Beowulf installer has corrected this confusion.
#3 2020-02-17 01:02:48
bgstack15
Woops, I got this too, in an Ascii 2.0 installer. Guess I need to get the latest install media. I did remember that something was up with the "us.deb.devuan.org" stuff so I picked pkgmaster...
#4 2020-02-17 01:14:26
pkgmaster is the source for all the mirrors.  If it is used in sources.list, it will put on an extra load and could slow down the frequent mirror updates
#5 2020-02-17 17:17:29
nobodyuknow
@golinux
Thanks for the reply. Yes, I was using 2.0 media. I will correct my sources.list.
