#1 2020-02-05 14:36:14
tochiro
Sources.list broken
Hallo all big_smile
For my mistake, have broken "sources.list"......now i have this:
# Devuan repositories
deb https://deb.devuan.org/merged ascii main
deb https://deb.devuan.org/merged ascii-security main
deb https://deb.devuan.org/merged ascii-updates main
#deb https://deb.devuan.org/merged ascii-backports main
# Devuan sources
deb-src https://deb.devuan.org/merged ascii main
deb-src https://deb.devuan.org/merged ascii-security main
deb-src https://deb.devuan.org/merged ascii-updates main
#deb-src https://deb.devuan.org/merged ascii-backports main
When write "sudo apt update" return me :
"E: La riga 1 nel file /etc/apt/sources.list non è corretta (type)
E: Impossibile leggere l'elenco dei sorgenti."
P.S. Sorry for my bad english
#2 2020-02-05 14:43:04
Re: Sources.list broken
Not all mirrors support https. If you use deb.devuan.org it may redirect you to an http mirror or an https mirror, so it will sometimes fail.
To use https, select a mirror that supports https and use that in your sources.list
Here's a list of package mirrors. Each entry shows which protocols are supported:
http://pkgmaster.devuan.org/mirror_list.txt
#3 2020-02-05 16:33:13
tochiro
deb http://deb.devuan.org/merged ascii          main
deb http://deb.devuan.org/merged ascii-updates  main
deb http://deb.devuan.org/merged ascii-security main
# Devuan sources
deb-src http://deb.devuan.org/merged ascii main
deb-src http://deb.devuan.org/merged ascii-security main
deb-src http://deb.devuan.org/merged ascii-updates main
As usual return me:
mad
#4 2020-02-05 17:03:04
nixer
A simple question here, but did you run
apt update
after editing your sources.list file and before trying to update?
I mention this as I have overlooked simple things myself, and will again.
#5 2020-02-05 17:13:25
My /etc/apt/sources.list contains
## package repositories
deb http://deb.devuan.org/merged/ ascii main contrib non-free
deb http://deb.devuan.org/merged/ ascii-updates main contrib non-free
deb http://deb.devuan.org/merged/ ascii-security main contrib non-free
# deb http://deb.devuan.org/merged/ ascii-backports main
## source repositories
# deb-src http://deb.devuan.org/merged/ ascii main
# deb-src http://deb.devuan.org/merged/ ascii-updates main
# deb-src http://deb.devuan.org/merged/ ascii-security main
# deb-src http://deb.devuan.org/merged/ ascii-backports main
Note there is a / after merged which you do not have. Try adding that.
Chris
#6 2020-02-05 17:19:10
Just tried to update my ASCII installation, works like a charm.
My sources.list also contains contrib and non-free, and also includes backports and proposed updates, here is the first line:
deb http://deb.devuan.org/merged ascii main contrib non-free
Found 35 updates.
I can't see a mistake in your sources.list. Try again apt update, apt list --upgradable, apt upgrade.
#7 2020-02-05 17:32:17
There is no "/" after merged in the Devuan documentation.
#8 2020-02-05 17:33:38
tochiro wrote:
As usual return me:
Please post the output of
sudo LC_ALL=C apt update
^ That will make the command speak English.
Perhaps you have a weird character in the file that's not showing up when you paste it here, try copy&pasting chris2be8's list into a fresh sources.list file.
#9 2020-02-06 09:13:20
mmaglis
translates to:
Line 1 in the /etc/apt/sources.list file is incorrect (type)
Unable to read the source list.
Check
  • what is the file's first line. Any funny character?
  • the permissions of the file /etc/apt/sources.list
#10 2020-02-06 15:09:04
@tochiro: please post the output of
cat -v /etc/apt/sources.list
^ That should show any non-printable characters.
Or:
sed -n 'l' /etc/apt/sources.list
^ That should display most non-printable characters as the octal values.
For example the new lines will be marked with a $ symbol.
#11 2020-02-06 17:37:39
Are there tabs instead of spaces in your /etc/apt/sources.list ? Or any other strange characters?
If you can't see anything post output from od -xc /etc/apt/sources.list here (it will be a bit lengthy).
Chris
