#1 2020-01-14 14:05:09
farmatito
[SOLVED] Bug tracking system access problems
while trying to see my reported bug 373 I was unable to access with Firefox 68.4.1-ESR to the bug tracking system.
The error message was:
           Did Not Connect: Potential Security Issue
           Firefox detected a potential security threat and did not continue to debbugs.devuan.dev
           because this website requires a secure connection.
           What can you do about it?
           debbugs.devuan.dev has a security policy called HTTP Strict Transport Security (HSTS),
           which means that Firefox can only connect to it securely. You can’t add an exception to visit this site.
           The issue is most likely with the website, and there is nothing you can do to resolve it.
           You can notify the website’s administrator about the problem.
Any work arounds?
#2 2020-01-14 16:22:04
Re: [SOLVED] Bug tracking system access problems
Use chromium or palemoon or [your alternate browser of choice] until we work around the after-migration glitches.
#3 2020-01-15 13:00:58
farmatito
Works now!!! Thanks!!
